[postgis-tickets] r15922 - Generate postgis.control at make time, not configure time
Sandro Santilli strk at kbt.io
Fri Oct 6 06:29:02 PDT 2017
Author: strk
Date: 2017-10-06 06:29:01 -0700 (Fri, 06 Oct 2017)
New Revision: 15922
   trunk/configure.ac
   trunk/extensions/postgis/Makefile.in
   trunk/extensions/postgis/postgis.control.in
Modified: trunk/configure.ac
--- trunk/configure.ac	2017-10-06 13:21:38 UTC (rev 15921)
+++ trunk/configure.ac	2017-10-06 13:29:01 UTC (rev 15922)
@@ -1432,7 +1432,6 @@
 AC_OUTPUT([GNUmakefile
    extensions/Makefile
-   extensions/postgis/postgis.control
    extensions/postgis_sfcgal/Makefile
    extensions/postgis_sfcgal/postgis_sfcgal.control
    extensions/postgis_topology/Makefile
Modified: trunk/extensions/postgis/Makefile.in
--- trunk/extensions/postgis/Makefile.in	2017-10-06 13:21:38 UTC (rev 15921)
+++ trunk/extensions/postgis/Makefile.in	2017-10-06 13:29:01 UTC (rev 15922)
@@ -3,6 +3,7 @@
 EXTENSION     = postgis
 EXTVERSION    = @POSTGIS_LIB_VERSION@
 MINORVERSION  = @POSTGIS_MAJOR_VERSION at .@POSTGIS_MINOR_VERSION@
+MODULEPATH    = $$libdir/$(EXTENSION)-$(MINORVERSION)
 GREP = @GREP@
 PERL = @PERL@
@@ -23,6 +24,7 @@
                         $(PERL) -pe 's/(\d+[a-zA-Z]+)\d*/\1/'
 DATA_built = \
+	$(EXTENSION).control \
 	sql/$(EXTENSION)--$(EXTVERSION).sql \
 	sql/$(EXTENSION)--unpackaged--$(EXTVERSION).sql \
 	$(NULL)
@@ -44,6 +46,13 @@
 	printf '\\echo Use "CREATE EXTENSION $(EXTENSION)" to load this file. \\quit\n' > $@
 	cat $^ >> $@
+$(EXTENSION).control: $(EXTENSION).control.in Makefile
+	cat $< \
+		| sed -e 's|@EXTVERSION@|$(EXTVERSION)|g' \
+		| sed -e 's|@EXTENSION@|$(EXTENSION)|g' \
+		| sed -e 's|@MODULEPATH@|$(MODULEPATH)|g' \
 sql/$(EXTENSION)--$(EXTVERSION).sql: sql/$(EXTENSION).sql
 	mkdir -p sql
 	cp $< $@
Modified: trunk/extensions/postgis/postgis.control.in
--- trunk/extensions/postgis/postgis.control.in	2017-10-06 13:21:38 UTC (rev 15921)
+++ trunk/extensions/postgis/postgis.control.in	2017-10-06 13:29:01 UTC (rev 15922)
@@ -1,5 +1,5 @@
 # postgis extension
 comment = 'PostGIS geometry, geography, and raster spatial types and functions'
-default_version = '@POSTGIS_LIB_VERSION@'
-module_pathname = '$libdir/postgis- at POSTGIS_MAJOR_VERSION@. at POSTGIS_MINOR_VERSION@'
+default_version = '@EXTVERSION@'
+module_pathname = '@MODULEPATH@'
 relocatable = false
