[postgis-tickets] [PostGIS] #3859: Remove rt* targets from postgis extension Makefile if --without-raster is set
trac at osgeo.org
Fri Oct 6 08:18:49 PDT 2017
set
Reporter: giohappy | Owner: strk
Type: defect | Status: reopened
Priority: medium | Milestone: PostGIS 2.5.0
Component: build/upgrade/install | Version: trunk
Resolution: | Keywords:
Changes (by robe):
* status: closed => reopened
* resolution: wontfix =>
* milestone: PostGIS 2.4.0 => PostGIS 2.5.0
Comment:
I'm reopening this, we've been talking aobut the possiblity of having an
extension without raster and encoding that in the version number.
Something also will be the possibility of disabling all GEOS functions if
a new feature --without-geos is specified. Both are on the table and I'm
planning to make a motion vote about it.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3859#comment:4>
