[postgis-tickets] [PostGIS] #3883: Make B-Tree sorting blazingly fast
trac at osgeo.org
Fri Oct 6 11:22:09 PDT 2017
Reporter: komzpa | Owner: pramsey
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 2.5.0
Component: postgis | Version: 2.4.x
Keywords: |
- make gserialized_get_sort_hash function;
- make it return least possible value on EMPTY;
- make it read not box, but first coordinate of gserialized. This way no
geography/geometry branching is needed, and it should be faster than
getting a float-rounded box center for geometries that don't store it;
- make fast path for complete equality for fast GROUP BY in
gserizlized_cmp;
- create sortsupport function that will employ gserialized_get_sort_hash
and full equality fast path;
- investigate when to abort abbreviated compare in sort. (this is going
to happen more often on 32bit machines, as sortsupport key will be 32bit,
containing half of 64bit key).
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3883>
