[postgis-tickets] r15926 - Mark non-mutating segmentize functions as const
Paul Ramsey
pramsey at cleverelephant.ca
Fri Oct 6 14:49:20 PDT 2017
Author: pramsey
Date: 2017-10-06 14:49:20 -0700 (Fri, 06 Oct 2017)
New Revision: 15926
trunk/liblwgeom/liblwgeom.h.in
trunk/liblwgeom/lwcollection.c
trunk/liblwgeom/lwgeom.c
trunk/liblwgeom/lwline.c
trunk/liblwgeom/lwpoly.c
Modified: trunk/liblwgeom/liblwgeom.h.in
--- trunk/liblwgeom/liblwgeom.h.in 2017-10-06 21:19:44 UTC (rev 15925)
+++ trunk/liblwgeom/liblwgeom.h.in 2017-10-06 21:49:20 UTC (rev 15926)
@@ -1474,11 +1474,11 @@
* Ensure every segment is at most 'dist' long.
* Returned LWGEOM might is unchanged if a POINT.
-extern LWGEOM *lwgeom_segmentize2d(LWGEOM *line, double dist);
+extern LWGEOM *lwgeom_segmentize2d(const LWGEOM *line, double dist);
extern POINTARRAY *ptarray_segmentize2d(const POINTARRAY *ipa, double dist);
-extern LWLINE *lwline_segmentize2d(LWLINE *line, double dist);
-extern LWPOLY *lwpoly_segmentize2d(LWPOLY *line, double dist);
-extern LWCOLLECTION *lwcollection_segmentize2d(LWCOLLECTION *coll, double dist);
+extern LWLINE *lwline_segmentize2d(const LWLINE *line, double dist);
+extern LWPOLY *lwpoly_segmentize2d(const LWPOLY *line, double dist);
+extern LWCOLLECTION *lwcollection_segmentize2d(const LWCOLLECTION *coll, double dist);
* Point density functions
Modified: trunk/liblwgeom/lwcollection.c
--- trunk/liblwgeom/lwcollection.c 2017-10-06 21:19:44 UTC (rev 15925)
+++ trunk/liblwgeom/lwcollection.c 2017-10-06 21:49:20 UTC (rev 15926)
@@ -234,7 +234,7 @@
LWCOLLECTION *
-lwcollection_segmentize2d(LWCOLLECTION *col, double dist)
+lwcollection_segmentize2d(const LWCOLLECTION *col, double dist)
uint32_t i;
LWGEOM **newgeoms;
Modified: trunk/liblwgeom/lwgeom.c
--- trunk/liblwgeom/lwgeom.c 2017-10-06 21:19:44 UTC (rev 15925)
+++ trunk/liblwgeom/lwgeom.c 2017-10-06 21:49:20 UTC (rev 15926)
@@ -745,7 +745,7 @@
LWGEOM *
-lwgeom_segmentize2d(LWGEOM *lwgeom, double dist)
+lwgeom_segmentize2d(const LWGEOM *lwgeom, double dist)
switch (lwgeom->type)
Modified: trunk/liblwgeom/lwline.c
--- trunk/liblwgeom/lwline.c 2017-10-06 21:19:44 UTC (rev 15925)
+++ trunk/liblwgeom/lwline.c 2017-10-06 21:49:20 UTC (rev 15926)
@@ -138,7 +138,7 @@
LWLINE *
-lwline_segmentize2d(LWLINE *line, double dist)
+lwline_segmentize2d(const LWLINE *line, double dist)
POINTARRAY *segmentized = ptarray_segmentize2d(line->points, dist);
if ( ! segmentized ) return NULL;
Modified: trunk/liblwgeom/lwpoly.c
--- trunk/liblwgeom/lwpoly.c 2017-10-06 21:19:44 UTC (rev 15925)
+++ trunk/liblwgeom/lwpoly.c 2017-10-06 21:49:20 UTC (rev 15926)
@@ -309,7 +309,7 @@
LWPOLY *
-lwpoly_segmentize2d(LWPOLY *poly, double dist)
+lwpoly_segmentize2d(const LWPOLY *poly, double dist)
POINTARRAY **newrings;
uint32_t i;
