[postgis-tickets] r15934 - Do not suggest to uninstall postgis when already found
Sandro Santilli
strk at kbt.io
Sun Oct 8 11:20:00 PDT 2017
Author: strk
Date: 2017-10-08 11:20:00 -0700 (Sun, 08 Oct 2017)
New Revision: 15934
trunk/postgis/postgis.sql.in
The user might want to upgrade it or package it instead...
Modified: trunk/postgis/postgis.sql.in
--- trunk/postgis/postgis.sql.in 2017-10-07 21:52:16 UTC (rev 15933)
+++ trunk/postgis/postgis.sql.in 2017-10-08 18:20:00 UTC (rev 15934)
@@ -35,7 +35,7 @@
WHERE p.proname = 'postgis_version'
AND p.pronamespace = n.oid
LOOP
- RAISE EXCEPTION 'PostGIS is already installed in schema ''%'', uninstall it first', rec.nspname;
+ RAISE EXCEPTION 'PostGIS is already installed in schema ''%''', rec.nspname;
END LOOP;
END
$$ LANGUAGE 'plpgsql';
@@ -1290,15 +1290,15 @@
RETURNS float8
AS 'MODULE_PATHNAME', 'LWGEOM_azimuth'
LANGUAGE 'c' IMMUTABLE STRICT _PARALLEL;
-- Availability: 2.5.0
CREATE OR REPLACE FUNCTION ST_Angle(pt1 geometry, pt2 geometry, pt3 geometry, pt4 geometry default 'POINT EMPTY'::geometry)
RETURNS float8
AS 'MODULE_PATHNAME', 'LWGEOM_angle'
LANGUAGE 'c' IMMUTABLE STRICT;
-- MISC
