[postgis-tickets] [PostGIS] #3893: Add safety check for raster support to be in same schema as postgis
trac at osgeo.org
Mon Oct 9 07:40:46 PDT 2017
Reporter: strk | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.4.1
Component: postgis | Version: 2.4.x
Keywords: |
Regina reported that raster and core should be in the same schema or bad
things can happen. This ticket is to add a safety check in raster enabler
script to make sure this is the case.
Regina it would be great to have an example of such bad thing,
and we should make sure that non-extension load doesn't suffer form these
bad things either (setting search_path for each installed function?)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3893>
