[postgis-tickets] r15938 - Forbid creating raster support objects in a schema != PostGIS one
Sandro Santilli
strk at kbt.io
Mon Oct 9 08:45:50 PDT 2017
Author: strk
Date: 2017-10-09 08:45:49 -0700 (Mon, 09 Oct 2017)
New Revision: 15938
trunk/NEWS
trunk/raster/rt_pg/rtpostgis.sql.in
Fixes #3893
Modified: trunk/NEWS
--- trunk/NEWS 2017-10-08 20:38:06 UTC (rev 15937)
+++ trunk/NEWS 2017-10-09 15:45:49 UTC (rev 15938)
@@ -6,6 +6,8 @@
* Breaking Changes *
- #3885, version number removed from address_standardize lib file
+ - #3893, raster support functions can only be loaded in the same schema
+ with core PostGIS functions.
PostGIS 2.4.0
2017/09/30
Modified: trunk/raster/rt_pg/rtpostgis.sql.in
--- trunk/raster/rt_pg/rtpostgis.sql.in 2017-10-08 20:38:06 UTC (rev 15937)
+++ trunk/raster/rt_pg/rtpostgis.sql.in 2017-10-09 15:45:49 UTC (rev 15938)
@@ -56,7 +56,26 @@
END
$$ LANGUAGE 'plpgsql';
+-- Check that postgis raster is being installed in the same
+-- schema as PostGIS
+DO $$
+DECLARE
+ nsp TEXT;
+BEGIN
+ SELECT n.nspname
+ INTO nsp FROM pg_proc p, pg_namespace n
+ WHERE p.proname = 'postgis_lib_version'
+ AND p.pronamespace = n.oid;
+ IF nsp != current_schema() THEN
+ RAISE EXCEPTION
+ 'PostGIS Raster must be in the same schema as PostGIS (%)',
+ nsp;
+ END IF;
+END
+$$ LANGUAGE 'plpgsql';
-- RASTER Type
