[postgis-tickets] [PostGIS] #3893: Add safety check for raster support to be in same schema as postgis
trac at osgeo.org
Mon Oct 9 08:48:06 PDT 2017
Reporter: strk | Owner: pramsey
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.4.1
Component: postgis | Version: 2.4.x
Resolution: fixed | Keywords:
Comment (by strk):
See how you like r15938 - I listed it as a breaking change because
people might be installing raster in a different schema, at the
moment, relying on search_path to eventually find PostGIS.
Doing the search_path setting ourselves would still be nice
but seems to be worth another ticket (to remove the limitation
of same-schema).
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3893#comment:6>
