[postgis-tickets] [PostGIS] #3892: Review safety and behavior of CREATE EXTENSION from UNPACKAGED
trac at osgeo.org
Mon Oct 9 12:59:29 PDT 2017
Reporter: strk | Owner: pramsey
Type: task | Status: new
Priority: high | Milestone: PostGIS 2.4.1
Component: postgis | Version: 2.4.x
Resolution: | Keywords:
Comment (by robe):
strk,
I did a test and though it's unorthodox, you can move a function from one
extension to another with a unpackaged.
So I created a blackhole extension:
-- blackhole.control looks like this
comment = 'Black Hole'
default_version = '1.0'
relocatable = true
-- blackhole--unpackaged--1.0.sql
CREATE OR REPLACE FUNCTION do_something() RETURNS text AS
SELECT 'test';
$$ language sql;
ALTER EXTENSION postgis DROP FUNCTION _add_raster_constraint_blocksize(
rastschema name,
rasttable name,
rastcolumn name,
axis text);
ALTER EXTENSION blackhole ADD FUNCTION _add_raster_constraint_blocksize(
rastschema name,
rasttable name,
rastcolumn name,
axis text);
Then I did
CREATE EXTENSION postgis;
CREATE EXTENSION blackhole FROM unpackaged;
DROP EXTENSION postgis;
And all that was left was the function I moved into the black hole and the
do_something function defined in the black hole.
So I guess as long as you stuff the raster upgrade script in the
unpackaged script you can do it.
So the instruction would be, if you use raster and want to keep it, first
run
CREATE EXTENSION postgis_raster FROM unpackaged;
ALTER EXTENSION postgis UPDATE;
The ALTER EXTENSION postgis would remove all raster functions/type (both
drop the function and remove from postgis). It will gracefully fail if
the user has raster and your warning would be, to fix
Do the above.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3892#comment:1>
