[postgis-tickets] [PostGIS] #3892: Review safety and behavior of CREATE EXTENSION from UNPACKAGED
PostGIS trac at osgeo.org
Mon Oct 9 17:31:55 PDT 2017
  Reporter:  strk     |      Owner:  pramsey
      Type:  task     |     Status:  new
  Priority:  high     |  Milestone:  PostGIS 2.4.1
 Component:  postgis  |    Version:  2.4.x
Resolution:           |   Keywords:
Comment (by robe):
 Ah that sorry I misunderstood the question.
 It assumes the version you have in your database is what you installed.
 For most extensions that generally works because they rarely add new
 functions.  For us not so much.
 People would have to know what version of postgis they installed and do
 something like
 CREATE EXTENSION postgis FROM unpackaged VERSION "2.4.0";
 So it would run the version 2.4.0 script instead of the default 2.5.0
 script.
 or you'd put in a guard in the unpackaged script to check (so you'll still
 need to isntall one of our temporary helper functions) and error out.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3892#comment:3>
