[postgis-tickets] [PostGIS] #3838: topology.toTopoGeom fails with ERROR: XX000: SQL/MM Spatial exception - geometry crosses, when using tolerance 10 meter
trac at osgeo.org
Tue Oct 10 03:36:38 PDT 2017
Reporter: laopsahl | Owner: strk
Type: defect | Status: assigned
Priority: medium | Milestone: PostGIS 2.3.4
Component: topology | Version: 2.3.x
Resolution: | Keywords: totopogeom, ERROR: XX000: SQL/MM
Changes (by strk):
* cc: aperi (added)
Comment:
See the damage made by snapper:
[[Image(brokensnap.png)]]
It may help to rewrite the snapping algorithm, maybe porting portions of
https://git.osgeo.org/gogs/rttopo/librttopo/src/master/src/rtt_tpsnap.c
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3838#comment:7>
