[postgis-tickets] r15945 - lw_dist2d_pt_arc division by zero (References #3874)
Paul Ramsey
pramsey at cleverelephant.ca
Tue Oct 10 09:36:56 PDT 2017
Author: pramsey
Date: 2017-10-10 09:36:55 -0700 (Tue, 10 Oct 2017)
New Revision: 15945
branches/2.4/NEWS
branches/2.4/liblwgeom/cunit/cu_measures.c
branches/2.4/liblwgeom/measures.c
Modified: branches/2.4/NEWS
--- branches/2.4/NEWS 2017-10-10 16:33:41 UTC (rev 15944)
+++ branches/2.4/NEWS 2017-10-10 16:36:55 UTC (rev 15945)
@@ -11,6 +11,7 @@
- #3880, Undefined behaviour in TYPMOD_GET_SRID
- #3875, Fix undefined behaviour in shift operation
- #3864, Performance improvements for b-tree geometry sorts
+ - #3874, lw_dist2d_pt_arc division by zero
PostGIS 2.4.0
Modified: branches/2.4/liblwgeom/cunit/cu_measures.c
--- branches/2.4/liblwgeom/cunit/cu_measures.c 2017-10-10 16:33:41 UTC (rev 15944)
+++ branches/2.4/liblwgeom/cunit/cu_measures.c 2017-10-10 16:36:55 UTC (rev 15945)
@@ -534,6 +534,13 @@
CU_ASSERT_EQUAL( rv, LW_SUCCESS );
CU_ASSERT_DOUBLE_EQUAL(dl.distance, 0, 0.000001);
+ /* Point on semicircle center */
+ P.x = 0 ; P.y = 0;
+ lw_dist2d_distpts_init(&dl, DIST_MIN);
+ rv = lw_dist2d_pt_arc(&P, &A1, &A2, &A3, &dl);
+ CU_ASSERT_EQUAL( rv, LW_SUCCESS );
+ CU_ASSERT_DOUBLE_EQUAL(dl.distance, 1, 0.000001);
/* Point inside closed circle */
P.x = 0 ; P.y = 0.5;
A2.x = 1; A2.y = 0;
Modified: branches/2.4/liblwgeom/measures.c
--- branches/2.4/liblwgeom/measures.c 2017-10-10 16:33:41 UTC (rev 15944)
+++ branches/2.4/liblwgeom/measures.c 2017-10-10 16:36:55 UTC (rev 15945)
@@ -1455,6 +1455,15 @@
/* Distance from point to center */
d = distance2d_pt_pt(&C, P);
+ /* P is the center of the circle */
+ if ( FP_EQUALS(d, 0.0) )
+ dl->distance = radius_A;
+ dl->p1 = *A1;
+ dl->p2 = *P;
+ return LW_TRUE;
/* X is the point on the circle where the line from P to C crosses */
X.x = C.x + (P->x - C.x) * radius_A / d;
X.y = C.y + (P->y - C.y) * radius_A / d;
