[postgis-tickets] r15950 - Fix undefined behaviour in zigzag with negative inputs (2.4 branch)
Paul Ramsey pramsey at cleverelephant.ca
Tue Oct 10 09:59:11 PDT 2017
Author: pramsey
Date: 2017-10-10 09:59:11 -0700 (Tue, 10 Oct 2017)
New Revision: 15950
   branches/2.2/NEWS
   branches/2.2/liblwgeom/cunit/cu_varint.c
   branches/2.2/liblwgeom/varint.c
   branches/2.2/liblwgeom/varint.h
(References #3882)
Modified: branches/2.2/NEWS
--- branches/2.2/NEWS	2017-10-10 16:59:04 UTC (rev 15949)
+++ branches/2.2/NEWS	2017-10-10 16:59:11 UTC (rev 15950)
@@ -14,6 +14,7 @@
   - #3880, Undefined behaviour in TYPMOD_GET_SRID
   - #3875, Fix undefined behaviour in shift operation
   - #3874, lw_dist2d_pt_arc division by zero
+  - #3882, undefined behaviour in zigzag with negative inputs
 PostGIS 2.2.5
Modified: branches/2.2/liblwgeom/cunit/cu_varint.c
--- branches/2.2/liblwgeom/cunit/cu_varint.c	2017-10-10 16:59:04 UTC (rev 15949)
+++ branches/2.2/liblwgeom/cunit/cu_varint.c	2017-10-10 16:59:11 UTC (rev 15950)
@@ -36,16 +36,16 @@
 	int size;
 	char *hex;
 	uint8_t buf[16];
 	size = varint_u32_encode_buf(nr, buf);
 	if ( size != expected_size )
 		printf("Expected: %d\nObtained: %d\n", expected_size, size);
 	CU_ASSERT_EQUAL(size, expected_size);
 	hex = hexbytes_from_bytes(buf, size);
-	ASSERT_STRING_EQUAL(hex, expected_res);
-	lwfree(hex);
+	ASSERT_STRING_EQUAL(hex, expected_res);
+	lwfree(hex);
 static void do_test_s32_varint(int32_t nr,int expected_size, char* expected_res)
@@ -53,7 +53,7 @@
 	uint8_t buf[16];
 	int size;
 	char *hex;
 	size = varint_s32_encode_buf(nr, buf);
@@ -62,7 +62,7 @@
 	CU_ASSERT_EQUAL(size,expected_size);
 	lwfree(hex);
@@ -71,7 +71,7 @@
 	uint8_t buf[16];
 	int size;
 	char *hex;
 	size = varint_u64_encode_buf(nr, buf);
@@ -89,16 +89,16 @@
 	uint8_t buf[16];
 	int size;
 	char *hex;
 	size = varint_s64_encode_buf(nr, buf);
 	hex = hexbytes_from_bytes(buf,size);
 	lwfree(hex);
@@ -217,13 +217,27 @@
 		a = b = i;
 		CU_ASSERT_EQUAL(a, unzigzag64(zigzag64(a)));
-		CU_ASSERT_EQUAL(b, unzigzag32(zigzag64(b)));
+		CU_ASSERT_EQUAL(b, unzigzag32(zigzag32(b)));
 		a = b = -1 * i;
+	//8
+	CU_ASSERT_EQUAL(-INT8_MAX, unzigzag8(zigzag8(-INT8_MAX)));
+	CU_ASSERT_EQUAL(INT8_MAX, unzigzag8(zigzag8(INT8_MAX)));
+	CU_ASSERT_EQUAL(0, unzigzag8(zigzag8(0)));
+	//32
+	CU_ASSERT_EQUAL(-INT32_MAX, unzigzag32(zigzag32(-INT32_MAX)));
+	CU_ASSERT_EQUAL(INT32_MAX, unzigzag32(zigzag32(INT32_MAX)));
+	CU_ASSERT_EQUAL(0, unzigzag32(zigzag32(0)));
+	//64
+	CU_ASSERT_EQUAL(-INT64_MAX, unzigzag64(zigzag64(-INT64_MAX)));
+	CU_ASSERT_EQUAL(INT64_MAX, unzigzag64(zigzag64(INT64_MAX)));
+	CU_ASSERT_EQUAL(0, unzigzag64(zigzag64(0)));
Modified: branches/2.2/liblwgeom/varint.c
--- branches/2.2/liblwgeom/varint.c	2017-10-10 16:59:04 UTC (rev 15949)
+++ branches/2.2/liblwgeom/varint.c	2017-10-10 16:59:11 UTC (rev 15950)
@@ -25,7 +25,7 @@
 static size_t
 _varint_u64_encode_buf(uint64_t val, uint8_t *buf)
-	uint8_t grp;
+	uint8_t grp;
 	uint64_t q = val;
 	uint8_t *ptr = buf;
 	while (1)
@@ -35,7 +35,7 @@
 		/* We rightshift our input value 7 bits */
 		/* which means that the 7 next least significant bits */
 		/* becomes the 7 least significant */
-		q = q >> 7;
+		q = q >> 7;
 		/* Check if, after our rightshifting, we still have */
 		/* anything to read in our input value. */
 		if ( q > 0 )
@@ -92,7 +92,7 @@
 /* Read from signed 64bit varint */
 int64_t
 varint_s64_decode(const uint8_t *the_start, const uint8_t *the_end, size_t *size)
 	return unzigzag64(varint_u64_decode(the_start, the_end, size));
@@ -159,41 +159,42 @@
 uint64_t zigzag64(int64_t val)
-	return (val << 1) ^ (val >> 63);
+	return val >= 0 ?
+		((uint64_t)val) << 1 :
+		((((uint64_t)(-1 - val)) << 1) | 0x01);
 uint32_t zigzag32(int32_t val)
-	return (val << 1) ^ (val >> 31);
+	return val >= 0 ?
+		((uint32_t)val) << 1 :
+		((((uint32_t)(-1 - val)) << 1) | 0x01);
 uint8_t zigzag8(int8_t val)
-	return (val << 1) ^ (val >> 7);
+	return val >= 0 ?
+		((uint8_t)val) << 1 :
+		((((uint8_t)(-1 - val)) << 1) | 0x01);
 int64_t unzigzag64(uint64_t val)
-        if ( val & 0x01 )
-            return -1 * (int64_t)((val+1) >> 1);
-        else
-            return (int64_t)(val >> 1);
+	return !(val & 0x01) ?
+		((int64_t)(val >> 1)) :
+		(-1 * (int64_t)((val+1) >> 1));
 int32_t unzigzag32(uint32_t val)
-        if ( val & 0x01 )
-            return -1 * (int32_t)((val+1) >> 1);
-        else
-            return (int32_t)(val >> 1);
+		((int32_t)(val >> 1)) :
+		(-1 * (int32_t)((val+1) >> 1));
 int8_t unzigzag8(uint8_t val)
-        if ( val & 0x01 )
-            return -1 * (int8_t)((val+1) >> 1);
-        else
-            return (int8_t)(val >> 1);
+		((int8_t)(val >> 1)) :
+		(-1 * (int8_t)((val+1) >> 1));
Modified: branches/2.2/liblwgeom/varint.h
--- branches/2.2/liblwgeom/varint.h	2017-10-10 16:59:04 UTC (rev 15949)
+++ branches/2.2/liblwgeom/varint.h	2017-10-10 16:59:11 UTC (rev 15950)
@@ -34,6 +34,8 @@
 size_t varint_size(const uint8_t *the_start, const uint8_t *the_end);
+/* Support from -INT{8,32,64}_MAX to INT{8,32,64}_MAX),
+ * e.g INT8_MIN is not supported in zigzag8 */
 uint64_t zigzag64(int64_t val);
 uint32_t zigzag32(int32_t val);
 uint8_t zigzag8(int8_t val);
