[postgis-tickets] r15955 - Undefined behaviour in pointarray_to_encoded_polyline (2.4 branch)
Paul Ramsey pramsey at cleverelephant.ca
Tue Oct 10 11:04:57 PDT 2017
Author: pramsey
Date: 2017-10-10 11:04:56 -0700 (Tue, 10 Oct 2017)
New Revision: 15955
   branches/2.4/NEWS
   branches/2.4/liblwgeom/lwout_encoded_polyline.c
(References #3891)
Modified: branches/2.4/NEWS
--- branches/2.4/NEWS	2017-10-10 18:04:45 UTC (rev 15954)
+++ branches/2.4/NEWS	2017-10-10 18:04:56 UTC (rev 15955)
@@ -13,6 +13,7 @@
   - #3864, Performance improvements for b-tree geometry sorts
   - #3874, lw_dist2d_pt_arc division by zero
   - #3882, undefined behaviour in zigzag with negative inputs
+  - #3891, undefined behaviour in pointarray_to_encoded_polyline
 PostGIS 2.4.0
Modified: branches/2.4/liblwgeom/lwout_encoded_polyline.c
--- branches/2.4/liblwgeom/lwout_encoded_polyline.c	2017-10-10 18:04:45 UTC (rev 15954)
+++ branches/2.4/liblwgeom/lwout_encoded_polyline.c	2017-10-10 18:04:56 UTC (rev 15955)
@@ -73,7 +73,7 @@
 	stringbuffer_t *sb;
 	double scale = pow(10,precision);
-	/* Take the double value and multiply it by 1x10^percision, rounding the result */
+	/* Take the double value and multiply it by 1x10^precision, rounding the result */
 	prevPoint = getPoint2d_cp(pa, 0);
 	delta[0] = round(prevPoint->y*scale);
 	delta[1] = round(prevPoint->x*scale);
@@ -90,8 +90,8 @@
 	/* value to binary: a negative value must be calculated using its two's complement */
 	for (i=0; i<pa->npoints*2; i++)
-		/* Left-shift the binary value one bit */
-		delta[i] <<= 1;
+		/* Multiply by 2 for a signed left shift */
+		delta[i] *= 2;
 		/* if value is negative, invert this encoding */
 		if (delta[i] < 0) {
 			delta[i] = ~(delta[i]);
