[postgis-tickets] [PostGIS] #3896: postgis_extensions_upgrade function to upgrade all your packaged postgis extensions
PostGIS trac at osgeo.org
Wed Oct 11 02:15:35 PDT 2017
extensions
  Reporter:  robe                   |      Owner:  strk
      Type:  enhancement            |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 2.5.0
 Component:  build/upgrade/install  |    Version:  trunk
Resolution:                         |   Keywords:
Comment (by strk):
 Also, it could be useful if this function would also check for unpackaged
 extensions and raised a WARNING about that: "extension XXX is unpackaged,
 so it won't be possible to upgrade with this function, HINT: create from
 unpackaged..."
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3896#comment:3>
