[postgis-tickets] [PostGIS] #3864: Sorting by geometry is slower than sorting by geohash
trac at osgeo.org
Wed Oct 11 02:40:11 PDT 2017
Reporter: komzpa | Owner: pramsey
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.4.1
Component: postgis | Version: 2.3.x
Resolution: fixed | Keywords:
Comment (by komzpa):
Bigint sorted sort is the same time as sorted geom and is almost same as
unsorted bigint. Geohash time is same as unsorted Geohash.
[local] gis at gis=# create table juno_osm_point_pt1_fastmath_ordered as
(select * from juno_osm_point_pt1_fastmath ORDER BY
ST_GeoHash(ST_Transform(ST_Envelope(way),4326),10) COLLATE "C");
SELECT 159843185
Time: 935372,463 ms (15:35,372)
[local] gis at gis=# create table juno_osm_point_unclustered_ordered as
(select * from juno_osm_point_unclustered order by osm_id);
SELECT 159843185
Time: 596486,915 ms (09:56,487)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3864#comment:29>
