[postgis-tickets] [PostGIS] #3896: postgis_extensions_upgrade function to upgrade all your packaged postgis extensions
PostGIS trac at osgeo.org
Wed Oct 11 08:51:46 PDT 2017
extensions
  Reporter:  robe                   |      Owner:  strk
      Type:  enhancement            |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 2.5.0
 Component:  build/upgrade/install  |    Version:  trunk
Resolution:                         |   Keywords:
Comment (by robe):
 I'm working on one.  I figure I should have a pull request like yours so I
 can learn about checkout and git branching and tagging.  If it doesn't go
 then I'll just commit without the noraster bit as you suggest.
 https://git.osgeo.org/gogs/robe/postgis/src/postgis-extension-noraster
 also make sure there are no flaws in my approach which I hadn't thought
 of. Then people can test both approaches and see which they prefer.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3896#comment:7>
