[postgis-tickets] r15971 - Add option to always upgrade a dev version to default dev version even if already at the default version.
Regina Obe
lr at pcorp.us
Wed Oct 11 23:50:32 PDT 2017
Author: robe
Date: 2017-10-11 23:50:32 -0700 (Wed, 11 Oct 2017)
New Revision: 15971
trunk/postgis/postgis.sql.in
References #3898 for PostGIS 2.5.0 (trunk)
Modified: trunk/postgis/postgis.sql.in
--- trunk/postgis/postgis.sql.in 2017-10-11 17:11:50 UTC (rev 15970)
+++ trunk/postgis/postgis.sql.in 2017-10-12 06:50:32 UTC (rev 15971)
@@ -2793,19 +2793,31 @@
-- Availability: 2.5.0
CREATE OR REPLACE FUNCTION postgis_extensions_upgrade() RETURNS text
AS $$
-DECLARE rec record;
+DECLARE rec record; sql text;
BEGIN
- FOR rec in SELECT 'ALTER EXTENSION ' || name || ' UPDATE TO ' || quote_ident(default_version) || ';' AS sql
- FROM pg_available_extensions
- WHERE installed_version > '' AND name IN('postgis', 'postgis_sfcgal', 'postgis_tiger_geocoder', 'postgis_topology')
- AND ( default_version <> installed_version ) LOOP
+ -- if at a version different from default version or we are at a dev version,
+ -- then do an upgrade to default version
- EXECUTE rec.sql;
- RAISE NOTICE '%', rec.sql;
-END LOOP;
+ FOR rec in SELECT name, default_version, installed_version
+ FROM pg_available_extensions
+ WHERE installed_version > '' AND name IN('postgis', 'postgis_sfcgal', 'postgis_tiger_geocoder', 'postgis_topology')
+ AND ( default_version <> installed_version OR
+ ( default_version = installed_version AND default_version ILIKE '%dev%' AND installed_version ILIKE '%dev%' ) ) LOOP
-RETURN @extschema at .postgis_full_version();
+ -- we need to upgrade to next so our installed is different from current
+ -- and then we can upgrade to default_version
+ IF rec.installed_version = rec.default_version THEN
+ sql = 'ALTER EXTENSION ' || rec.name || ' UPDATE TO ' || quote_ident(rec.default_version || 'next') || ';';
+ EXECUTE sql;
+ RAISE NOTICE '%', sql;
+ END IF;
+ END LOOP;
+ RETURN @extschema at .postgis_full_version();
END
$$ language plpgsql;
