[postgis-tickets] [PostGIS] #3898: ANY-2.5.0dev is showing as an upgrade option
trac at osgeo.org
Thu Oct 12 01:08:42 PDT 2017
Reporter: robe | Owner: strk
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.5.0
Component: build/upgrade/install | Version: trunk
Resolution: fixed | Keywords:
Comment (by strk):
Unintentional, looks like I forgot a dash. You'll have to clean that up
manually or "make uninstall" before updating codebase to r15974 in order
to test the fix.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3898#comment:3>
