[postgis-tickets] [PostGIS] #3898: ANY-2.5.0dev is showing as an upgrade option
PostGIS trac at osgeo.org
Thu Oct 12 08:28:37 PDT 2017
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  closed
  Priority:  medium                 |  Milestone:  PostGIS 2.5.0
 Component:  build/upgrade/install  |    Version:  trunk
Resolution:  fixed                  |   Keywords:
Comment (by strk):
 Regina it should be installed by {{{ make install }}} which should call
 {{{ make install-upgrade-paths }}} which would call this:
 install-upgrade-paths: sql_bits/postgis_extension_upgrade_minor.sql
   tpl='$(EXTENSION)--ANY--$(EXTVERSION).sql'; \
   ln -fs "$${tpl}"
 $(EXTDIR)/$(EXTENSION)--$(EXTVERSION)--$(EXTVERSION)next.sql; \
   ln -fs "$${tpl}"
 $(EXTDIR)/$(EXTENSION)--$(EXTVERSION)next--$(EXTVERSION).sql; \
   $(INSTALL_DATA) $^ "$(EXTDIR)/$${tpl}"; \
   for OLD_VERSION in $(UPGRADEABLE_VERSIONS); do \
     ln -fs "$${tpl}"
 $(EXTDIR)/$(EXTENSION)--$$OLD_VERSION--$(EXTVERSION).sql; \
   done
 See the "next" part is installing a symlink to {{{ ${tpl} }}} which should
 be the ANY file.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3898#comment:5>
