[postgis-tickets] r15975 - BTree sorting logic fix
Sandro Santilli
strk at kbt.io
Thu Oct 12 09:30:17 PDT 2017
Author: strk
Date: 2017-10-12 09:30:17 -0700 (Thu, 12 Oct 2017)
New Revision: 15975
trunk/liblwgeom/g_serialized.c
Sort geometries that have different length but same prefix
- allow fast path for geography points
- fix gcc warnings
- compare EMPTY geometries as normal memcmp path
Patch by Darafei Praliaskouski <me at komzpa.net>
Fixes #3899
Modified: trunk/liblwgeom/g_serialized.c
--- trunk/liblwgeom/g_serialized.c 2017-10-12 08:08:11 UTC (rev 15974)
+++ trunk/liblwgeom/g_serialized.c 2017-10-12 16:30:17 UTC (rev 15975)
@@ -300,27 +300,25 @@
union floatuint x, y;
- * For two non-same planar points, we can skip a lot of machinery.
+ * For two non-same points, we can skip a lot of machinery.
if (
sz1 > 16 && // 16 is size of EMPTY, if it's larger - it has coordinates
sz2 > 16 &&
- *(uint32_t*)(g1->data) == POINTTYPE &&
- *(uint32_t*)(g2->data) == POINTTYPE &&
+ *(uint32_t*)(g1 + 2 * sizeof(uint32_t)) == POINTTYPE &&
+ *(uint32_t*)(g2 + 2 * sizeof(uint32_t)) == POINTTYPE &&
!FLAGS_GET_BBOX(g1->flags) &&
- !FLAGS_GET_GEODETIC(g1->flags) &&
- !FLAGS_GET_BBOX(g2->flags) &&
- !FLAGS_GET_GEODETIC(g2->flags)
+ !FLAGS_GET_BBOX(g2->flags)
- double *dptr = (double*)(g1->data);
- x.f = 2.0 * dptr[1];
- y.f = 2.0 * dptr[2];
+ double *dptr = (double*)(g1->data + sizeof(double));
+ x.f = 2.0 * dptr[0];
+ y.f = 2.0 * dptr[1];
hash1 = uint32_interleave_2(x.u, y.u);
- dptr = (double*)(g2->data);
+ dptr = (double*)(g2->data + sizeof(double));
hash2 = uint32_interleave_2(x.u, y.u);
if ( hash1 > hash2 )
@@ -345,22 +343,12 @@
g1_is_empty = (gserialized_get_gbox_p(g1, &box1) == LW_FAILURE);
g2_is_empty = (gserialized_get_gbox_p(g2, &box2) == LW_FAILURE);
- /* Empty == Empty */
- if (g1_is_empty && g2_is_empty)
- /* POINT EMPTY == POINT EMPTY */
- /* POINT EMPTY < LINESTRING EMPTY */
- uint32_t t1 = gserialized_get_type(g1);
- uint32_t t2 = gserialized_get_type(g2);
- return t1 == t2 ? 0 : (t1 < t2 ? -1 : 1);
/* Empty < Non-empty */
- if (g1_is_empty)
+ if (g1_is_empty && !g2_is_empty)
return -1;
/* Non-empty > Empty */
- if (g2_is_empty)
+ if (!g2_is_empty && g2_is_empty)
return 1;
/* Return equality for perfect equality only */
@@ -368,47 +356,51 @@
if ( bsz1 == bsz2 && cmp_srid == 0 && cmp == 0 )
return 0;
- /* Using the centroids, calculate somewhat sortable */
- /* hash key. The key doesn't provide good locality over */
- /* the +/- boundary, but otherwise is pretty OK */
- hash1 = gbox_get_sortable_hash(&box1);
- hash2 = gbox_get_sortable_hash(&box2);
+ if (!g1_is_empty && !g2_is_empty)
+ /* Using the centroids, calculate somewhat sortable */
+ /* hash key. The key doesn't provide good locality over */
+ /* the +/- boundary, but otherwise is pretty OK */
+ hash1 = gbox_get_sortable_hash(&box1);
+ hash2 = gbox_get_sortable_hash(&box2);
- if ( hash1 > hash2 )
- return 1;
- else if ( hash1 < hash2 )
- return -1;
+ if ( hash1 > hash2 )
+ return 1;
+ else if ( hash1 < hash2 )
+ return -1;
- /* What, the hashes are equal? OK... sort on the */
- /* box minima */
- if (box1.xmin < box2.xmin)
- return -1;
- else if (box1.xmin > box2.xmin)
- return 1;
+ /* What, the hashes are equal? OK... sort on the */
+ /* box minima */
+ if (box1.xmin < box2.xmin)
+ return -1;
+ else if (box1.xmin > box2.xmin)
+ return 1;
- if (box1.ymin < box2.ymin)
- return -1;
- else if (box1.ymin > box2.ymin)
- return 1;
+ if (box1.ymin < box2.ymin)
+ return -1;
+ else if (box1.ymin > box2.ymin)
+ return 1;
- /* Still equal? OK... sort on the box maxima */
- if (box1.xmax < box2.xmax)
- return -1;
- else if (box1.xmax > box2.xmax)
- return 1;
+ /* Still equal? OK... sort on the box maxima */
+ if (box1.xmax < box2.xmax)
+ return -1;
+ else if (box1.xmax > box2.xmax)
+ return 1;
- if (box1.ymax < box2.ymax)
- return -1;
- else if (box1.ymax > box2.ymax)
- return 1;
+ if (box1.ymax < box2.ymax)
+ return -1;
+ else if (box1.ymax > box2.ymax)
+ return 1;
- /* Geeze! How about object size? Sort on that... */
- if (hsz1 < hsz2)
- return -1;
- else if (hsz1 > hsz2)
- return 1;
- /* OK fine, we'll sort on the memcmp just to be done with this */
+ /* Prefix comes before longer one. */
+ if (bsz1 != bsz2 && cmp == 0)
+ if (bsz1 < bsz2)
+ return -1;
+ else if (bsz1 > bsz2)
+ return 1;
return cmp == 0 ? 0 : (cmp > 0 ? 1 : -1);
@@ -1563,4 +1555,3 @@
return lwgeom;
