[postgis-tickets] [PostGIS] #3901: winnie extension upgrade is failing
trac at osgeo.org
Thu Oct 12 21:08:00 PDT 2017
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.5.0
Component: buildbots | Version: trunk
Keywords: |
As noted on #3898
ALTER EXTENSION is failing on winnie.
I think this is because of the way I install on the VC++ build since make
install gets installed on mingw64 (and I was in habit of copying directly
from extension/sql folder which I can't do anymore now that everything is
linked to ANY.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3901>
