[postgis-tickets] [PostGIS] #3903: ST_AsGeoJSON not working with LineStringM
trac at osgeo.org
Fri Oct 13 14:14:31 PDT 2017
Reporter: ccsmith | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.4.1
Component: postgis | Version: 2.1.x
Keywords: ST_AsGeoJSON, LineStringM |
When using ST_AsGeoJSON with a LineStringM or LineStringMZ (and coordinate
values for the M dimension) geometry there is no resulting coordinate
output for the M dimension.
--POSTGIS VERSION
SELECT PostGIS_full_version();
"POSTGIS="2.1.8 r13780" GEOS="3.5.0-CAPI-1.9.0 r4084" PROJ="Rel. 4.9.2, 08
September 2015" GDAL="GDAL 1.11.5, released 2016/07/01" LIBXML="2.9.1"
LIBJSON="UNKNOWN" RASTER"
--LINESTRING
select ST_ASgeojson(ST_GeomFromText('LINESTRING(1 0, 2 0, 4 0)'));
{"type":"LineString","coordinates":[[1,0],[2,0],[4,0]]}
--LINESTRINGM
select ST_ASgeojson(ST_GeomFromText('**LINESTRINGM**(**1 0 0, 2 0 10, 4 0
20**)'));
{"type":"LineString","coordinates":[**[1,0],[2,0],[4,0]**]}
--LINESTRINGZ
select ST_ASgeojson(ST_GeomFromText('LINESTRINGz(1 0 0, 2 0 10, 4 0 20)'))
{"type":"LineString","coordinates":[[1,0,0],[2,0,10],[4,0,20]]}
--LINESTRINGZM
select ST_ASgeojson(ST_GeomFromText('**LINESTRINGZM**(**1 0 0 0, 2 0 10 0,
4 0 20 0**)'))
{"type":"LineString","coordinates":[**[1,0,0],[2,0,10],[4,0,20]**]}
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3903>
