[postgis-tickets] r15980 - Try to fix next scripts not being installed on windows by moving linking step to after install of ANY script
Regina Obe lr at pcorp.us
Fri Oct 13 21:27:56 PDT 2017
Author: robe
Date: 2017-10-13 21:27:56 -0700 (Fri, 13 Oct 2017)
New Revision: 15980
   trunk/extensions/postgis/Makefile.in
Assumption being the fact ANY doesn't exist at time of link is causing problems
References #3901
Modified: trunk/extensions/postgis/Makefile.in
--- trunk/extensions/postgis/Makefile.in	2017-10-13 05:40:27 UTC (rev 15979)
+++ trunk/extensions/postgis/Makefile.in	2017-10-14 04:27:56 UTC (rev 15980)
@@ -134,9 +134,9 @@
 # revisions of the same version
 install-upgrade-paths: sql_bits/postgis_extension_upgrade_minor.sql
 	tpl='$(EXTENSION)--ANY--$(EXTVERSION).sql'; \
+	$(INSTALL_DATA) $^ "$(EXTDIR)/$${tpl}"; \
 	ln -fs "$${tpl}" $(EXTDIR)/$(EXTENSION)--$(EXTVERSION)--$(EXTVERSION)next.sql; \
 	ln -fs "$${tpl}" $(EXTDIR)/$(EXTENSION)--$(EXTVERSION)next--$(EXTVERSION).sql; \
-	$(INSTALL_DATA) $^ "$(EXTDIR)/$${tpl}"; \
 	for OLD_VERSION in $(UPGRADEABLE_VERSIONS); do \
 		ln -fs "$${tpl}" $(EXTDIR)/$(EXTENSION)--$$OLD_VERSION--$(EXTVERSION).sql; \
 	done
