[postgis-tickets] [PostGIS] #3901: winnie extension upgrade is failing
PostGIS trac at osgeo.org
Fri Oct 13 21:27:57 PDT 2017
  Reporter:  robe       |      Owner:  robe
      Type:  defect     |     Status:  reopened
  Priority:  medium     |  Milestone:  PostGIS 2.5.0
 Component:  buildbots  |    Version:  trunk
Resolution:             |   Keywords:
Comment (by robe):
 In [changeset:"15980" 15980]:
 #!CommitTicketReference repository="" revision="15980"
 Try to fix next scripts not being installed on windows by moving linking
 step to after install of ANY script
 Assumption being the fact ANY doesn't exist at time of link is causing
 problems
 References #3901
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3901#comment:5>
