[postgis-tickets] [PostGIS] #3815: Tiger 2017 data support
PostGIS trac at osgeo.org
Sat Oct 14 07:07:25 PDT 2017
  Reporter:  robe            |      Owner:  robe
      Type:  enhancement     |     Status:  new
  Priority:  medium          |  Milestone:  PostGIS 2.5.0
 Component:  tiger geocoder  |    Version:  trunk
Resolution:                  |   Keywords:
Comment (by robe):
 In [changeset:"15984" 15984]:
 #!CommitTicketReference repository="" revision="15984"
 Fix tiger 2017 edges load issue by doing following:
  insert to be ordered by column name instead of ordinal_position.
   Exclude divroad from edges load which now appears to be no longer
 present in 2017 edges data.
 References #3815 for trunk PostGIS 2.5.0
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3815#comment:5>
