[postgis-tickets] r15989 - flag zcta5 addition as an enhancement not a change. References #3815
Regina Obe lr at pcorp.us
Mon Oct 16 02:00:02 PDT 2017
Author: robe
Date: 2017-10-16 02:00:02 -0700 (Mon, 16 Oct 2017)
New Revision: 15989
   trunk/doc/extras_tigergeocoder.xml
Modified: trunk/doc/extras_tigergeocoder.xml
--- trunk/doc/extras_tigergeocoder.xml	2017-10-16 06:18:08 UTC (rev 15988)
+++ trunk/doc/extras_tigergeocoder.xml	2017-10-16 09:00:02 UTC (rev 15989)
@@ -840,7 +840,7 @@
             <para><varname>loader_lookuptables</varname> each record defines a kind of table (state, county), whether to process records in it and how to load them in.  Defines the steps to import data, stage data, add, removes columns, indexes, and constraints for each.  Each table is prefixed with the state and inherits from a table in the tiger schema. e.g. creates <varname>tiger_data.ma_faces</varname> which inherits from <varname>tiger.faces</varname></para>
           </listitem>
         </orderedlist>
-        <para>Changed: 2.4.1 zip code 5 tabulation area (zcta5) load step was fixed and when enabled, zcta5 data is loaded as a single table called zcta5_all as part of the nation script load.</para>
+        <para>Enhanced: 2.4.1 zip code 5 tabulation area (zcta5) load step was fixed and when enabled, zcta5 data is loaded as a single table called zcta5_all as part of the nation script load.</para>
         <para>Availability: 2.1.0 </para>
         <note><para>If you want zip code 5 tabulation area (zcta5) to be included in your nation script load, do the following:</para> <programlisting>UPDATE tiger.loader_lookuptables SET load = true WHERE table_name = 'zcta510';</programlisting></note>
         <note><para>If you were running <varname>tiger_2010</varname> version and you want to reload as state with newer tiger data, you'll need to for the very first load generate and run drop statements <xref linkend="Drop_Nation_Tables_Generate_Script" /> before you run this script.</para></note>
