[postgis-tickets] [PostGIS] #3905: Extend ST_SetEffectiveArea so it also works on start/endpoints of polygons
trac at osgeo.org
Mon Oct 16 04:27:04 PDT 2017
Reporter: tomvantilburg | Owner: pramsey
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 2.4.1
Component: postgis | Version: 2.4.x
Keywords: ST_SetEffectiveArea |
''ST_SetEffectiveArea'' (and hence ''ST_SimplifyVW'') always sets the
points related to start and endpoint of a polygon to ''dbl_max'' (example
below). While this is logical for linestrings (it would break your network
otherwise), it could be implemented better for polygons by reconnecting
the polygon when start/endpoint are throw out because of a small effective
area. This would be useful for example when polygons have spikes
originating from the startpoint that are supposed to be removed by this
algorithm.
Not to break existing behaviour or break existing topological nodes this
should be optional.
Also see this thread: [https://lists.osgeo.org/pipermail/postgis-
devel/2017-October/026669.html]
Example:
SELECT
ST_AsTExt(
(ST_DumpPoints(
ST_SetEffectiveArea(
ST_GeometryFromText(
'POLYGON((
0 0,
10 0,
20 0,
20 10,
10 10,
10 0,
0 0
,0.1)
)).geom)
Result:
"POINT M (0 0 3.40282346638529e+38)"
"POINT M (20 0 3.40282346638529e+38)"
"POINT M (20 10 3.40282346638529e+38)"
"POINT M (10 10 50)"
"POINT M (10 0 50)"
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3905>
