[postgis-tickets] [PostGIS] #886: Fix normalizing of multi street number range addresses and fractional street numbers
trac at osgeo.org
Mon Oct 16 12:14:26 PDT 2017
street numbers
Reporter: robe | Owner: robe
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.4.0
Component: tiger geocoder | Version: trunk
Resolution: fixed | Keywords:
Changes (by robe):
* status: new => closed
* resolution: => fixed
* milestone: PostGIS Fund Me => PostGIS 2.4.0
Comment:
This actually got fixed in 2.4.0 well close enough because Leo kept on
nagging me about his street numbers being mangled so
So new output in normalize_address, and pagc_address outputs a new column
address_alphanumeric which preserves the original street number. I forget
when I change the streetnumber to just take the first part. I think that
was before 2.4
SELECT j.key, j.value FROM
json_each_text(to_json(normalize_address('123-125 Washington Avenue,
Boston MA 02130'))) AS j;
key | value
address | 123
predirabbrev | NULL
streetname | Washington
streettypeabbrev | Ave
postdirabbrev | NULL
internal | NULL
location | Boston
stateabbrev | MA
zip | 02130
parsed | true
zip4 | NULL
address_alphanumeric | 123-125
(12 rows)
json_each_text(to_json(pagc_normalize_address('123-125 Washington Avenue,
key | value
address | 123
predirabbrev | NULL
streetname | WASHINGTON
streettypeabbrev | AVE
internal | NULL
location | BOSTON
stateabbrev | MA
zip | 02130
parsed | true
zip4 | NULL
address_alphanumeric | 123 125
(12 rows)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/886#comment:6>
