[postgis-tickets] [PostGIS] #3716: Gist index irrational growth
trac at osgeo.org
Mon Oct 16 12:17:16 PDT 2017
Reporter: Marcin Piotrowski | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone:
Component: postgis | Version: 2.1.x
Resolution: | Keywords:
Description changed by pramsey:
Old description:
> etry column).
> The size was not shrinked during autovacuum, only full vacuum was able to
> free the disk space.
> This is reproducable using following example that inserts 10000 rows and
> performs 1000 updates on the status column. After that index size is 321
> MB
> (321 MB of indexed nulls ! )
> -- psql script to create the database
> CREATE DATABASE gist_weirdness WITH TEMPLATE = template0 ENCODING =
> 'UTF8'
> LC_COLLATE = 'en_US.utf8' LC_CTYPE = 'en_US.utf8';
> \connect gist_weirdness
> CREATE EXTENSION IF NOT EXISTS plpgsql WITH SCHEMA pg_catalog;
> CREATE EXTENSION IF NOT EXISTS postgis WITH SCHEMA public;
> CREATE TABLE table_with_gist (
> id integer NOT NULL,
> status character varying(10),
> geompolygon geometry(Polygon,4326)
> CREATE SEQUENCE table_with_gist_id_seq
> START WITH 1
> INCREMENT BY 1
> NO MINVALUE
> NO MAXVALUE
> CACHE 1;
> ALTER TABLE ONLY table_with_gist ALTER COLUMN id SET DEFAULT
> nextval('table_with_gist_id_seq'::regclass);
> CREATE INDEX incidents_geompolygon_idx ON table_with_gist USING gist
> (geompolygon);
> -- pgscript to insert data
> DECLARE @I;
> set @I = 0;
> while @I < 10000
> begin
> INSERT INTO table_with_gist(status) VALUES (cast (@I as CHARACTER
> VARYING));
> set @I = @I + 1;
> end
> --pgscript to update data
> DECLARE @I;
> set @I = 0;
> while @I < 1000
> begin
> update table_with_gist set status=status::integer+7;
> set @I = @I + 1;
> end
New description:
If you create a GiST index on a geometry(Polygon,4267) column and do
updates on the table, the index size grows enormously even if the indexed
column contains only nulls. This is a big problem that caused index to
grow to tens of gigabytes for a table with just about 10000 rows, where
indexed column contained only nulls, but was updated on a minutely basis
(but not on the geometry column). The size was not shrinked during
autovacuum, only full vacuum was able to free the disk space.
MB
CREATE DATABASE gist_weirdness WITH TEMPLATE = template0 ENCODING = 'UTF8'
START WITH 1
INCREMENT BY 1
NO MINVALUE
NO MAXVALUE
CACHE 1;
(geompolygon);
DECLARE @I;
set @I = 0;
while @I < 10000
begin
VARYING));
set @I = @I + 1;
end
DECLARE @I;
set @I = 0;
while @I < 1000
begin
set @I = @I + 1;
end
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3716#comment:2>
