[postgis-tickets] [PostGIS] #2909: bad dependency expression results in rule firing on subsequent make, and make install
trac at osgeo.org
Mon Oct 16 12:28:01 PDT 2017
make install
Reporter: gdt | Owner: strk
Type: defect | Status: new
Priority: low | Milestone: PostGIS 2.2.6
Component: build/upgrade/install | Version: 2.1.x
Resolution: | Keywords:
Changes (by robe):
* cc: gdt (added)
Comment:
gdt is this still an issue for you in 2.4? I don't think I've every run
into issue.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2909#comment:5>
