[postgis-tickets] [PostGIS] #3719: Error: Invalid number of points in LinearRing
PostGIS trac at osgeo.org
Tue Oct 17 00:50:19 PDT 2017
  Reporter:  tiiipponen  |      Owner:  pramsey
      Type:  defect      |     Status:  new
  Priority:  medium      |  Milestone:  PostGIS 2.3.4
 Component:  postgis     |    Version:  2.3.x
Resolution:              |   Keywords:
Comment (by tiiipponen):
 To make it clear what is the meaning of this ticket I try to clarify:
 We are big organization with big data and some of our data can not be
 published from PostGIS because of this error.
 Problem geometries are valid geometries.
 Web services are regularly using ST_Intersects function, but because of
 this ticket-problem:
 1. ST_Intersects doesn't return all geometries it should.
 or
 2. complete ST_Intersects-query returns error that is shouldn't return.
 These two erroneous results practically prevent publishing some valid data
 and prevent using PostGIS professionally to important data.
 I can see many less important tickets ahead of this and I would like you
 guys look this ticket a bit more serious. No harsh meaning, but just say
 this after 8 months waiting.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3719#comment:7>
