[postgis-tickets] r15996 - Allocate enough space for all possible GBOX string outputs.
Paul Ramsey
pramsey at cleverelephant.ca
Tue Oct 17 09:51:26 PDT 2017
Author: pramsey
Date: 2017-10-17 09:51:26 -0700 (Tue, 17 Oct 2017)
New Revision: 15996
trunk/liblwgeom/cunit/cu_geodetic.c
trunk/liblwgeom/g_box.c
>From Ra?\195?\186l Mar?\195?\173n Algunenano
References #3907
Modified: trunk/liblwgeom/cunit/cu_geodetic.c
--- trunk/liblwgeom/cunit/cu_geodetic.c 2017-10-17 14:36:15 UTC (rev 15995)
+++ trunk/liblwgeom/cunit/cu_geodetic.c 2017-10-17 16:51:26 UTC (rev 15996)
@@ -1569,6 +1569,28 @@
/* end #3393 */
+static void test_gbox_to_string_truncated(void)
+ GBOX g = {
+ .flags = 0,
+ .xmin = -DBL_MAX,
+ .xmax = -DBL_MAX,
+ .ymin = -DBL_MAX,
+ .ymax = -DBL_MAX,
+ .zmin = -DBL_MAX,
+ .zmax = -DBL_MAX,
+ .mmin = -DBL_MAX,
+ .mmax = -DBL_MAX,
+ FLAGS_SET_Z(g.flags, 1);
+ FLAGS_SET_M(g.flags, 1);
+ char *c = gbox_to_string(&g);
+ ASSERT_STRING_EQUAL(c, "GBOX((-1.7976931e+308,-1.7976931e+308,-1.7976931e+308,-1.7976931e+308),(-1.7976931e+308,-1.7976931e+308,-1.7976931e+308,-1.7976931e+308))");
+ lwfree(c);
** Used by test harness to register the tests in this file.
@@ -1598,4 +1620,5 @@
PG_ADD_TEST(suite, test_lwgeom_segmentize_sphere);
PG_ADD_TEST(suite, test_ptarray_contains_point_sphere);
PG_ADD_TEST(suite, test_ptarray_contains_point_sphere_iowa);
+ PG_ADD_TEST(suite, test_gbox_to_string_truncated);
Modified: trunk/liblwgeom/g_box.c
--- trunk/liblwgeom/g_box.c 2017-10-17 14:36:15 UTC (rev 15995)
+++ trunk/liblwgeom/g_box.c 2017-10-17 16:51:26 UTC (rev 15996)
@@ -403,7 +403,7 @@
char* gbox_to_string(const GBOX *gbox)
- static int sz = 128;
+ static int sz = 138;
char *str = NULL;
if ( ! gbox )
