[postgis-tickets] r15999 - Allocate enough space for all possible GBOX string outputs (Ra?\195?\186l Mar?\195?\173n Rodr?\195?\173guez)
Paul Ramsey pramsey at cleverelephant.ca
Tue Oct 17 09:55:53 PDT 2017
Author: pramsey
Date: 2017-10-17 09:55:53 -0700 (Tue, 17 Oct 2017)
New Revision: 15999
   branches/2.2/NEWS
   branches/2.2/liblwgeom/cunit/cu_geodetic.c
   branches/2.2/liblwgeom/g_box.c
References #3907
Modified: branches/2.2/NEWS
--- branches/2.2/NEWS	2017-10-17 16:54:52 UTC (rev 15998)
+++ branches/2.2/NEWS	2017-10-17 16:55:53 UTC (rev 15999)
@@ -17,6 +17,7 @@
   - #3882, undefined behaviour in zigzag with negative inputs
   - #3891, undefined behaviour in pointarray_to_encoded_polyline
   - #3895, throw error on malformed WKB input
+  - #3907, Allocate enough space for all possible GBOX string outputs (Raúl Marín Rodríguez)
 PostGIS 2.2.5
Modified: branches/2.2/liblwgeom/cunit/cu_geodetic.c
--- branches/2.2/liblwgeom/cunit/cu_geodetic.c	2017-10-17 16:54:52 UTC (rev 15998)
+++ branches/2.2/liblwgeom/cunit/cu_geodetic.c	2017-10-17 16:55:53 UTC (rev 15999)
@@ -1569,6 +1569,28 @@
 	/* end #3393 */
+static void test_gbox_to_string_truncated(void)
+	GBOX g = {
+		.flags = 0,
+		.xmin = -DBL_MAX,
+		.xmax = -DBL_MAX,
+		.ymin = -DBL_MAX,
+		.ymax = -DBL_MAX,
+		.zmin = -DBL_MAX,
+		.zmax = -DBL_MAX,
+		.mmin = -DBL_MAX,
+		.mmax = -DBL_MAX,
+	FLAGS_SET_Z(g.flags, 1);
+	FLAGS_SET_M(g.flags, 1);
+	char *c = gbox_to_string(&g);
+	ASSERT_STRING_EQUAL(c, "GBOX((-1.7976931e+308,-1.7976931e+308,-1.7976931e+308,-1.7976931e+308),(-1.7976931e+308,-1.7976931e+308,-1.7976931e+308,-1.7976931e+308))");
+	lwfree(c);
 ** Used by test harness to register the tests in this file.
@@ -1598,4 +1620,5 @@
 	PG_ADD_TEST(suite, test_lwgeom_segmentize_sphere);
 	PG_ADD_TEST(suite, test_ptarray_contains_point_sphere);
 	PG_ADD_TEST(suite, test_ptarray_contains_point_sphere_iowa);
+	PG_ADD_TEST(suite, test_gbox_to_string_truncated);
Modified: branches/2.2/liblwgeom/g_box.c
--- branches/2.2/liblwgeom/g_box.c	2017-10-17 16:54:52 UTC (rev 15998)
+++ branches/2.2/liblwgeom/g_box.c	2017-10-17 16:55:53 UTC (rev 15999)
@@ -368,7 +368,7 @@
 char* gbox_to_string(const GBOX *gbox)
-	static int sz = 128;
+	static int sz = 138;
 	char *str = NULL;
 	if ( ! gbox )
