[postgis-tickets] [PostGIS] #3838: topology.toTopoGeom fails with ERROR: XX000: SQL/MM Spatial exception - geometry crosses, when using tolerance 10 meter
trac at osgeo.org
Wed Oct 18 00:15:24 PDT 2017
Reporter: laopsahl | Owner: strk
Type: defect | Status: assigned
Priority: medium | Milestone: PostGIS 2.3.4
Component: topology | Version: 2.3.x
Resolution: | Keywords: totopogeom, ERROR: XX000: SQL/MM
Changes (by laopsahl):
* Attachment "break_up_reduce_1.png" added.
Existing data and new line to add
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3838>
