[postgis-tickets] r16008 - Prepare for 2.3.4 release
Paul Ramsey
pramsey at cleverelephant.ca
Wed Oct 18 11:09:59 PDT 2017
Author: pramsey
Date: 2017-10-18 11:09:59 -0700 (Wed, 18 Oct 2017)
New Revision: 16008
branches/2.3/ChangeLog
branches/2.3/HOWTO_RELEASE
branches/2.3/NEWS
branches/2.3/README.postgis
branches/2.3/Version.config
branches/2.3/doc/release_notes.xml
branches/2.3/extensions/upgradeable_versions.mk
Modified: branches/2.3/ChangeLog
--- branches/2.3/ChangeLog 2017-10-18 17:54:28 UTC (rev 16007)
+++ branches/2.3/ChangeLog 2017-10-18 18:09:59 UTC (rev 16008)
@@ -1,3 +1,348 @@
+2017-10-17 16:54 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r15998] NEWS, liblwgeom/cunit/cu_geodetic.c, liblwgeom/g_box.c:
+ Allocate enough space for all possible GBOX string outputs (Raúl
+ Marín Rodríguez)
+ Closes #3907
+2017-10-10 22:45 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r15959] NEWS, liblwgeom/lwin_wkb.c: Throw error on malformed WKB
+ input (2.3 branch)
+ Credit to OSS-Fuzz:
+ https://bugs.chromium.org/p/oss-fuzz/issues/detail?id=2589
+ https://bugs.chromium.org/p/oss-fuzz/issues/detail?id=2590
+ https://bugs.chromium.org/p/oss-fuzz/issues/detail?id=2591
+ https://bugs.chromium.org/p/oss-fuzz/issues/detail?id=2592
+ (References #3895)
+2017-10-10 18:04 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r15954] NEWS, liblwgeom/lwout_encoded_polyline.c: Undefined
+ behaviour in pointarray_to_encoded_polyline (2.3 branch)
+ (References #3891)
+2017-10-10 16:59 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r15949] NEWS, liblwgeom/cunit/cu_varint.c, liblwgeom/varint.c,
+ liblwgeom/varint.h: Fix undefined behaviour in zigzag with
+ negative inputs (2.4 branch)
+ (References #3882)
+2017-10-10 16:37 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r15946] NEWS, liblwgeom/cunit/cu_measures.c,
+ liblwgeom/measures.c: lw_dist2d_pt_arc division by zero
+ (References #3874)
+2017-10-06 13:21 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r15920] NEWS, liblwgeom/lwalgorithm.c: geohash_point_as_int: Fix
+ undefined behaviour in shift operation
+ References #3875
+2017-10-06 13:17 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r15916] NEWS, liblwgeom/cunit/cu_libgeom.c,
+ liblwgeom/liblwgeom.h.in: Undefined behaviour in TYPMOD_GET_SRID
+ References #3880
+2017-10-05 13:21 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r15901] NEWS, liblwgeom/cunit/cu_geodetic.c,
+ liblwgeom/cunit/cu_libgeom.c, liblwgeom/liblwgeom_internal.h,
+ liblwgeom/lwalgorithm.c, liblwgeom/lwgeodetic.c,
+ liblwgeom/lwgeodetic.h, liblwgeom/lwspheroid.c: Combine multiple
+ signum definitions (2.3)
+ (References #3878)
+2017-10-05 13:00 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r15898] NEWS, liblwgeom/cunit/cu_measures.c,
+ liblwgeom/measures.c: division by zero in lw_dist2d_arc_arc
+ References #3879
+2017-10-02 12:50 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r15871] NEWS, liblwgeom/lwlinearreferencing.c: Gracefully handle
+ short-measure issue (Closes #3845)
+2017-10-02 06:20 Sandro Santilli <strk at kbt.io>
+ * [r15867] NEWS, liblwgeom/Makefile.in: Add -lm to liblwgeom link
+ line
+ References #3869 for 2.3 branch
+2017-09-30 17:46 Sandro Santilli <strk at kbt.io>
+ * [r15861] .drone.yml: Fix yaml syntax in drone config
+2017-09-26 19:48 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r15838] NEWS: TWKB news item (References #3866)
+2017-09-26 19:10 Nicklas Avén <nicklas.aven at jordogskog.no>
+ * [r15837] liblwgeom/bytebuffer.c: increase possible size of varint
+2017-09-26 17:04 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r15835] NEWS, liblwgeom/lwin_wkb.c, liblwgeom/lwin_wkt.c:
+ Triangles un-closed in M should be WKT parseable (Closes #3818)
+2017-09-25 13:39 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r15815] NEWS, liblwgeom/lwstroke.c: Not-quite curved
+ CurvePolygon rejected by ST_Contains (Closes #3781)
+2017-09-20 00:19 Regina Obe <lr at pcorp.us>
+ * [r15776] NEWS, postgis/postgis.sql.in: ST_ConcaveHull fix for
+ ExteriorRing is not a polygon
+ References #2836 for PostGIS 2.3.4
+2017-09-18 21:59 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r15762] NEWS: News item (references #3731)
+2017-09-18 14:46 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r15761] NEWS: Added NEWS entry (references #3774)
+2017-09-18 13:27 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r15756] liblwgeom/lwcompound.c: Trig length calculation for
+ compoundcurve in 2.3 branch (references #3774)
+2017-09-14 22:58 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r15740] postgis/gserialized_estimate.c: #3731, backend crash on
+ zero size stats histogram
+2017-09-14 14:01 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r15724] extensions/address_standardizer/gamma.c,
+ loader/dbfopen.c, loader/pgsql2shp-core.c,
+ loader/shp2pgsql-core.c, raster/loader/raster2pgsql.c: #3847,
+ coverity fixes for 2.3
+2017-09-13 20:30 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r15718] doc/extras_topology.xml: Fix misplaced section end
+2017-09-13 20:21 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r15714] doc/extras_topology.xml: #3249, #2352, document
+ ST_RemoveIsoEdge
+2017-09-13 13:14 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r15709] topology/postgis_topology.c: Light PgSQL 11 support so I
+ can compile and test bug fixes
+2017-09-11 16:38 Sandro Santilli <strk at kbt.io>
+ * [r15686] .drone.yml: [drone] Extract upgrade target version
+ dynamically
+2017-09-11 15:50 Regina Obe <lr at pcorp.us>
+ * [r15683] NEWS, loader/shp2pgsql-core.c: initialize
+ state->num_fields and state->pgfieldtypes so doesn't cause
+ intermittent crashes on windows
+ Closes #3839 for PostGIS 2.3.4
+2017-09-11 15:16 Regina Obe <lr at pcorp.us>
+ * [r15682] loader/Makefile.in: always enable loader cunit tests
+ References #3839
+2017-09-07 05:51 Regina Obe <lr at pcorp.us>
+ * [r15645] extras/tiger_geocoder/geocode/reverse_geocode.sql: fix
+ field typo in reverse_geocoder
+ Closes #3833 for PostGIS 2.3.4
+2017-09-05 21:25 Sandro Santilli <strk at kbt.io>
+ * [r15635] configure.ac, libpgcommon/gserialized_gist.c,
+ postgis/gserialized_estimate.c, postgis/gserialized_gist_nd.c:
+ Revert "Rework PGSQL_VERSION again so to use 2-digits minor from
+ 10 onward"
+ This reverts commit r15631
+ For information about PostgreSQL versioning changes, see
+ https://git.postgresql.org/gitweb/?p=postgresql.git;a=commit;h=69dc5ae408f68c302029a6b43912a2cc16b1256c
+ Ref #3614
+2017-09-05 20:50 Sandro Santilli <strk at kbt.io>
+ * [r15632] NEWS: Add item about PostgreSQL 10 support
+ * [r15631] configure.ac, libpgcommon/gserialized_gist.c,
+ Rework PGSQL_VERSION again so to use 2-digits minor from 10
+ onward
+ See #3614 (for 2.3 branch)
+2017-09-05 20:37 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r15630] configure.ac, libpgcommon/gserialized_gist.c,
+ postgis/gserialized_estimate.c, postgis/gserialized_gist_nd.c,
+ raster/rt_pg/rtpostgis.sql.in, raster/test/regress/rt_union.sql,
+ raster/test/regress/rt_union_expected,
+ regress/regress_selectivity.sql,
+ topology/sql/topogeometry/totopogeom.sql.in,
+ topology/test/regress/copytopology.sql,
+ topology/test/regress/copytopology_expected: Support PgSQL 10 on
+ PostGIS 2.3
+2017-09-05 16:58 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r15627] liblwgeom/cunit/cu_geos.c, liblwgeom/lwgeom_geos.c:
+ #3829 Segfault in LWGEOM2GEOS
+2017-09-04 00:06 Daniel Baston <dbaston at gmail.com>
+ * [r15618] doc/reference_measure.xml: #3499, Clarify distance units
+ in docs for ST_ClusterWithin
+2017-09-01 14:00 Regina Obe <lr at pcorp.us>
+ * [r15612] doc/reference_processing.xml: Note that ST_Intersection
+ drops M
+ Closes #3826 for PostGIS 2.3.4
+2017-08-24 18:05 Regina Obe <lr at pcorp.us>
+ * [r15585] NEWS, doc/installation.xml,
+ extras/tiger_geocoder/tiger_loader_2016.sql: fix issues with
+ loading tabblock, incorporate changes from Jeffrey Wescott
+ change url to new census ssl one
+ update docs to describe how to load bg, tract, tabblock tables
+ Closes #3698 for PostGIS 2.3.4
+ Closes #3816 for PostGIS 2.3.4
+2017-08-24 03:00 Regina Obe <lr at pcorp.us>
+ * [r15579] extras/tiger_geocoder/census_loader.sql: delete no
+ longer used
+2017-08-20 06:31 Regina Obe <lr at pcorp.us>
+ * [r15557] doc/reference_measure.xml: Add reference to
+ ST_HausdorffDistance to ST_Distance function.
+ per Gary Turner
+ https://lists.osgeo.org/pipermail/postgis-users/2017-August/042322.html
+2017-08-18 04:02 Regina Obe <lr at pcorp.us>
+ * [r15554] NEWS, extras/tiger_geocoder/geocode/reverse_geocode.sql,
+ extras/tiger_geocoder/regress/reverse_geocode_regress,
+ extras/tiger_geocoder/regress/reverse_geocode_regress.sql:
+ Reverse geocoder missing street suffix direction.
+ Closes #3806 for PostGIS 2.3.4
+2017-08-10 09:36 Regina Obe <lr at pcorp.us>
+ * [r15547] .travis.yml: Fix travis build by changing permissions of
+ home folder
+ upgrade to test on 9.5
+ References #3803 for PostGIS 2.3.4
+ Closes https://github.com/postgis/postgis/pull/134
+2017-08-08 23:48 Regina Obe <lr at pcorp.us>
+ * [r15546] doc/reference_raster.xml: doc Patch from Even Rouault
+ Closes #3804 for PostGIS 2.3.4
+2017-08-08 15:36 Sandro Santilli <strk at kbt.io>
+ * [r15543] .editorconfig: Request crlf for .bat files
+2017-08-05 11:16 Regina Obe <lr at pcorp.us>
+ * [r15524] doc/reference_editor.xml: Clarify description of ST_Snap
+ that it is the newly snapped input geometry and will return input
+ geometry unchanged if no snapping.
+2017-08-04 23:02 Regina Obe <lr at pcorp.us>
+ * [r15523] loader/shp2pgsql-core.c: revert last change seems other
+ things I borught over from 2.4 where are unrelated to #3800
+2017-08-04 22:49 Regina Obe <lr at pcorp.us>
+ * [r15522] NEWS, loader/shp2pgsql-core.c, loader/shp2pgsql-gui.c:
+ Fix email addresses and credit stuff. shp2pgsql-gui Add support
+ for exporting materialized views, foreign tables, and partitioned
+ tables
+ Closes #3800 for PostGIS 2.3.4
+2017-07-28 04:09 Regina Obe <lr at pcorp.us>
+ * [r15514] NEWS, doc/xsl/postgis_aggs_mm.xml.xsl,
+ postgis/postgis.sql.in, postgis/sfcgal.sql.in: Mark 3D functions
+ and some other missed functions as parallel safe.
+ Closes #3792 for PostGIS 2.3.4
+2017-07-27 19:27 Regina Obe <lr at pcorp.us>
+ * [r15511] NEWS, postgis/gserialized_estimate.c: Solaris build
+ issues due to missing isfinite define
+ Patch from Julian Schauder
+ Closes #3795 for PostGIS 2.3.4
+2017-07-20 22:34 Regina Obe <lr at pcorp.us>
+ * [r15489] NEWS, liblwgeom/ptarray.c: OSS-Fuzz detected issues with
+ ptarray
+ References #3786 for PostGIS 2.3 (for 2.3.4)
+2017-07-10 18:00 Sandro Santilli <strk at kbt.io>
+ * [r15483] NEWS, loader/pgsql2shp-core.c: Fix buffer overflow and
+ use of uninitialized values
+ Closes #3101 for 2.3 branch
+2017-07-09 14:35 Regina Obe <lr at pcorp.us>
+ * [r15479] NEWS, liblwgeom/lwin_wkb.c: Memory leak in
+ lwline_from_wkb_state
+ Closes #3782 for PostGIS 2.3.4
+ Patch provided by Even Rouault
+2017-07-06 20:41 Regina Obe <lr at pcorp.us>
+ * [r15477] ci/winnie/package_postgis.sh: missing copying
+ libintl-8.dll needed for the VC++ 32-bit builds for postgis-gui
+2017-07-01 06:49 Regina Obe <lr at pcorp.us>
+ * [r15474] Version.config, extensions/upgradeable_versions.mk: bump
+ to 2.3.4dev
+2017-07-01 04:15 Regina Obe <lr at pcorp.us>
+ * [r15472] NEWS, README.postgis, Version.config,
+ doc/release_notes.xml: update version numbers, NEWS, release
+ notes in prep for PostGIS 2.3.3 release
+2017-07-01 03:22 Regina Obe <lr at pcorp.us>
+ * [r15470] ChangeLog: update ChangeLog in prep for PostGIS 2.3.3
+ release
2017-06-30 20:43 Regina Obe <lr at pcorp.us>
* [r15469] doc/performance_tips.xml, doc/using_postgis_dataman.xml:
Modified: branches/2.3/HOWTO_RELEASE
--- branches/2.3/HOWTO_RELEASE 2017-10-18 17:54:28 UTC (rev 16007)
+++ branches/2.3/HOWTO_RELEASE 2017-10-18 18:09:59 UTC (rev 16008)
@@ -39,11 +39,11 @@
Requirements
-In order to build a release, you will need to build PostGIS and the
+In order to build a release, you will need to build PostGIS and the
documentation -- that means having the required software:
* For PostGIS:
- - PostgreSQL
+ - PostgreSQL
- GEOS
- Proj4
- GDAL (for raster)
@@ -69,18 +69,18 @@
(this should only be needed for trunk release)
- Commit all changes
- If this is a minor or major release (no branch exists):
- $ base=http://svn.osgeo.org/postgis/
- $ rev=x.x
+ $ base=https://svn.osgeo.org/postgis/
+ $ rev=2.3.x
$ svn copy -m "Branch $rev" $base/trunk $base/branches/$rev
Go to: https://debbie.postgis.net and copy last branch version and make new job
a) Replace PostGIS_* string params with new version
b) Replace repository url with new branch repo url
c) Update the PostGIS_trunk by updating the PostGIS_* string params
d) create a new tagged branch job from latest tagged (and repeat a, b for this new tagged)
Go to: https://trac.osgeo.org/postgis/ edit the matrix to reflect new branch
- Tag branch: (replace x.x and x.x.x with minor and micro version e.g 2.3, 2.3.1
$ brev=x.x
@@ -89,7 +89,7 @@
- Run: sh make_dist.sh $rev (or use debbie for this)
- Build and test generated tarball (including extension upgrade)
- Copy tarball to web site and edit downloads page
-- Announce on e-mail
+- Announce on e-mail
- postgis-users
- postgis-devel
- pgsql-announce (send note to david at fetter dot org to be included in Weekly news)
@@ -101,7 +101,7 @@
b) Update links on https://git.osgeo.org/gogs/postgis/postgis.net/_content/pages/source.html
c) commit and wait 5 minutes to see changes on website
- PostGIS doc release versioned doc - http://postgis.net/documentation/
- (For building pdf, debbie has tagged jobs
+ (For building pdf, debbie has tagged jobs
-- http://debbie.postgis.net:8080 (log in)
Create new job copy last tag e.g. PostGIS_2.0_tagged_docs to PostGIS_2.1_tagged_docs
and make appropriate edits and then just run.
Modified: branches/2.3/NEWS
--- branches/2.3/NEWS 2017-10-18 17:54:28 UTC (rev 16007)
+++ branches/2.3/NEWS 2017-10-18 18:09:59 UTC (rev 16008)
@@ -1,5 +1,5 @@
PostGIS 2.3.4
-2017/xx/xx
+2017/10/18
* Bug Fixes and Enhancements
Modified: branches/2.3/README.postgis
--- branches/2.3/README.postgis 2017-10-18 17:54:28 UTC (rev 16007)
+++ branches/2.3/README.postgis 2017-10-18 18:09:59 UTC (rev 16008)
@@ -1,8 +1,8 @@
PostGIS - Geographic Information Systems Extensions to PostgreSQL
-:Version: 2.3.3
-:Date: 2017-07-01
+:Version: 2.3.4
+:Date: 2017-10-18
:Website: http://postgis.net
This distribution contains a module which implements GIS simple features, ties
Modified: branches/2.3/Version.config
--- branches/2.3/Version.config 2017-10-18 17:54:28 UTC (rev 16007)
+++ branches/2.3/Version.config 2017-10-18 18:09:59 UTC (rev 16008)
@@ -5,7 +5,7 @@
POSTGIS_MAJOR_VERSION=2
POSTGIS_MINOR_VERSION=3
-POSTGIS_MICRO_VERSION=4dev
+POSTGIS_MICRO_VERSION=4
# Liblwgeom interface versioning, reset to 0:0:0 (cur:age:rev)
# when changing POSTGIS_MINOR_VERSION
Modified: branches/2.3/doc/release_notes.xml
--- branches/2.3/doc/release_notes.xml 2017-10-18 17:54:28 UTC (rev 16007)
+++ branches/2.3/doc/release_notes.xml 2017-10-18 18:09:59 UTC (rev 16008)
@@ -3,6 +3,42 @@
<title>Appendix</title>
<subtitle>Release Notes</subtitle>
<sect1>
+ <title>Release 2.3.4</title>
+ <para>Release date: 2017/10/18</para>
+ <para>This is a bug fix and performance improvement release.</para>
+ <simplesect>
+ <title>Bug Fixes and Enhancements</title>
+ <para>PostgreSQL 10 support</para>
+ <para>#3782, Memory leak in lwline_from_wkb_state (Even Rouault)</para>
+ <para>#3101, Fix buffer overflow in pgsql2shp (Sandro Santilli)</para>
+ <para>#3786, ptarray null and heap issues on is_closed</para>
+ <para>#3795, Solaris build issues due to missing isfinite define (Julian Schauder)</para>
+ <para>#3792, mark all 3D related including SFCGAL as parallel safe</para>
+ <para>#3800, shp2pgql-gui allow export of foreign tables, materialized views, and partitioned tables</para>
+ <para>#3806, Reverse geocoder missing suffix direction when present</para>
+ <para>#3698, loading census tabblock is broken</para>
+ <para>#3839, loader tests sometimes crash because of variables not initialized also reenable cunit loader tess to always run.</para>
+ <para>#3774, Trigonometric length for CompoundCurves</para>
+ <para>#3731, Crash on very small table of homogenous data</para>
+ <para>#2836, Receiving ERROR: ExteriorRing: geom is not a polygon with ST_ConcaveHull</para>
+ <para>#3781, Not-quite curved CurvePolygon rejected by ST_Contains</para>
+ <para>#3818, Triangles unclosed in M should be parseable</para>
+ <para>#3866, Rare crash generating TWKB with large coordinate values</para>
+ <para>#3869, Fix build with "gold" linker</para>
+ <para>#3845, Gracefully handle short-measure issue</para>
+ <para>#3879, Division by zero in some arc cases</para>
+ <para>#3878, Single defn of signum in header</para>
+ <para>#3880, Undefined behaviour in TYPMOD_GET_SRID</para>
+ <para>#3875, Fix undefined behaviour in shift operation</para>
+ <para>#3874, lw_dist2d_pt_arc division by zero</para>
+ <para>#3882, undefined behaviour in zigzag with negative inputs</para>
+ <para>#3891, undefined behaviour in pointarray_to_encoded_polyline</para>
+ <para>#3895, throw error on malformed WKB input</para>
+ <para>#3907, Allocate enough space for all possible GBOX string outputs (Raúl Marín Rodríguez)</para>
+ </simplesect>
+ </sect1>
+ <sect1>
<title>Release 2.3.3</title>
<para>Release date: 2017/07/01</para>
Modified: branches/2.3/extensions/upgradeable_versions.mk
--- branches/2.3/extensions/upgradeable_versions.mk 2017-10-18 17:54:28 UTC (rev 16007)
+++ branches/2.3/extensions/upgradeable_versions.mk 2017-10-18 18:09:59 UTC (rev 16008)
@@ -25,7 +25,7 @@
2.2.5 \
2.3.0 \
2.3.1 \
- 2.3.2 \
+ 2.3.2 \
2.3.3
# This is to avoid forcing "check-installed-upgrades" as a default
