[postgis-tickets] r16014 - Quiet compile warnings
    Paul Ramsey
    pramsey at cleverelephant.ca
    Wed Oct 18 12:28:29 PDT 2017
Author: pramsey
Date: 2017-10-18 12:28:28 -0700 (Wed, 18 Oct 2017)
New Revision: 16014
   branches/2.4/liblwgeom/lwgeom_geos.c
   branches/2.4/postgis/geobuf.c
   branches/2.4/postgis/geography_centroid.c
   branches/2.4/postgis/gserialized_gist_2d.c
   branches/2.4/postgis/lwgeom_functions_basic.c
   branches/2.4/postgis/mvt.c
Modified: branches/2.4/liblwgeom/lwgeom_geos.c
--- branches/2.4/liblwgeom/lwgeom_geos.c	2017-10-18 18:46:27 UTC (rev 16013)
+++ branches/2.4/liblwgeom/lwgeom_geos.c	2017-10-18 19:28:28 UTC (rev 16014)
@@ -209,14 +209,14 @@
-GEOSCoordSeq ptarray_to_GEOSCoordSeq(const POINTARRAY *);
+GEOSCoordSeq ptarray_to_GEOSCoordSeq(const POINTARRAY *, int fix_ring);
 GEOSCoordSeq
-ptarray_to_GEOSCoordSeq(const POINTARRAY *pa)
+ptarray_to_GEOSCoordSeq(const POINTARRAY *pa, int fix_ring)
 	uint32_t dims = 2;
 	uint32_t i;
+	int append_points = 0;
 	const POINT3DZ *p3d;
 	const POINT2D *p2d;
 	GEOSCoordSeq sq;
@@ -224,8 +224,28 @@
 	if ( FLAGS_GET_Z(pa->flags) )
 		dims = 3;
-	if ( ! (sq = GEOSCoordSeq_create(pa->npoints, dims)) )
+	if ( fix_ring )
+		if (pa->npoints < 1)
+			lwerror("ptarray_to_GEOSCoordSeq called with fix_ring and 0 vertices in ring, cannot fix");
+			return NULL;
+		else
+			if ( pa->npoints < 4 )
+				append_points = 4 - pa->npoints;
+			if ( ! ptarray_is_closed_2d(pa) && append_points == 0 )
+				append_points = 1;
+	if ( ! (sq = GEOSCoordSeq_create(pa->npoints + append_points, dims)) )
 		lwerror("Error creating GEOS Coordinate Sequence");
 		return NULL;
@@ -248,47 +268,48 @@
 		GEOSCoordSeq_setY(sq, i, p2d->y);
 		if ( dims == 3 )
 			GEOSCoordSeq_setZ(sq, i, p3d->z);
-	return sq;
-static GEOSGeometry *
-ptarray_to_GEOSLinearRing(const POINTARRAY *pa, int autofix)
-	GEOSCoordSeq sq;
-	GEOSGeom g;
-	POINTARRAY *npa = 0;
-	if ( autofix )
+	if ( append_points )
-		if (pa->npoints < 1)
+		if ( dims == 3 )
-			lwerror("ptarray_to_GEOSLinearRing called with autofix and 0 vertices in ring, cannot fix");
+			p3d = getPoint3dz_cp(pa, 0);
+			p2d = (const POINT2D *)p3d;
-		* Check ring for being closed and fix if not.
-		* Also create a copy of geometry to operate on.
-		if ( ! ptarray_is_closed_2d(pa) || pa->npoints < 4 )
+		else
-			pa = ptarray_addPoint(pa, getPoint_internal(pa, 0), FLAGS_NDIMS(pa->flags), pa->npoints);
-			npa = pa;
+			p2d = getPoint2d_cp(pa, 0);
-		/* Check ring for having at least 4 vertices */
-		while ( pa->npoints < 4 )
+		for ( i = pa->npoints; i < pa->npoints + append_points; i++ )
-			ptarray_append_point(pa, getPoint_internal(pa, 0), LW_TRUE);
+			GEOSCoordSeq_setX(sq, i, p2d->x);
+			GEOSCoordSeq_setY(sq, i, p2d->y);
+			if ( dims == 3 )
+				GEOSCoordSeq_setZ(sq, i, p3d->z);
-	sq = ptarray_to_GEOSCoordSeq(pa);
-	if ( npa ) ptarray_free(npa);
+	return sq;
+static inline GEOSGeometry *
+ptarray_to_GEOSLinearRing(const POINTARRAY *pa, int autofix)
+	GEOSCoordSeq sq;
+	GEOSGeom g;
+	sq = ptarray_to_GEOSCoordSeq(pa, autofix);
 	g = GEOSGeom_createLinearRing(sq);
 	return g;
 GEOSGeometry *
 GBOX2GEOS(const GBOX *box)
@@ -373,7 +394,7 @@
 		else
-			sq = ptarray_to_GEOSCoordSeq(lwp->point);
+			sq = ptarray_to_GEOSCoordSeq(lwp->point, 0);
 			g = GEOSGeom_createPoint(sq);
 		if ( ! g )
@@ -388,11 +409,11 @@
 		if ( lwl->points->npoints == 1 ) {
 			/* Duplicate point, to make geos-friendly */
 			lwl->points = ptarray_addPoint(lwl->points,
-		                           getPoint_internal(lwl->points, 0),
-		                           FLAGS_NDIMS(lwl->points->flags),
-		                           lwl->points->npoints);
+			                       getPoint_internal(lwl->points, 0),
+			                       FLAGS_NDIMS(lwl->points->flags),
+			                       lwl->points->npoints);
-		sq = ptarray_to_GEOSCoordSeq(lwl->points);
+		sq = ptarray_to_GEOSCoordSeq(lwl->points, 0);
 		g = GEOSGeom_createLineString(sq);
 		if ( ! g )
@@ -568,8 +589,7 @@
 	if (result == NULL)
-	  lwerror("Error performing intersection: GEOS2LWGEOM: %s",
-	                lwgeom_geos_errmsg);
+		lwerror("Error performing intersection: GEOS2LWGEOM: %s", lwgeom_geos_errmsg);
 		return NULL ; /* never get here */
Modified: branches/2.4/postgis/geobuf.c
--- branches/2.4/postgis/geobuf.c	2017-10-18 18:46:27 UTC (rev 16013)
+++ branches/2.4/postgis/geobuf.c	2017-10-18 19:28:28 UTC (rev 16014)
@@ -564,7 +564,6 @@
 	bool isnull = false;
 	Datum datum;
 	Data__FeatureCollection *fc = ctx->data->feature_collection;
-	Data__Feature **features = fc->features;
 	Data__Feature *feature;
 	GSERIALIZED *gs;
 	if (fc->n_features >= ctx->features_capacity) {
Modified: branches/2.4/postgis/geography_centroid.c
--- branches/2.4/postgis/geography_centroid.c	2017-10-18 18:46:27 UTC (rev 16013)
+++ branches/2.4/postgis/geography_centroid.c	2017-10-18 19:28:28 UTC (rev 16014)
@@ -316,8 +316,6 @@
     POINT3DM points[size];
     uint32_t j = 0;
-    GBOX gbox;
     /* use first point as reference to create triangles */
     const POINT4D* reference_point = (const POINT4D*) getPoint2d_cp(mpoly->geoms[0]->rings[0], 0);
Modified: branches/2.4/postgis/gserialized_gist_2d.c
--- branches/2.4/postgis/gserialized_gist_2d.c	2017-10-18 18:46:27 UTC (rev 16013)
+++ branches/2.4/postgis/gserialized_gist_2d.c	2017-10-18 19:28:28 UTC (rev 16014)
@@ -589,7 +589,6 @@
 	GSERIALIZED *gpart;
 	uint8_t flags;
 	int result = LW_SUCCESS;
-	int gpart_is_slice = FALSE;
 	POSTGIS_DEBUG(4, "entered function");
Modified: branches/2.4/postgis/lwgeom_functions_basic.c
--- branches/2.4/postgis/lwgeom_functions_basic.c	2017-10-18 18:46:27 UTC (rev 16013)
+++ branches/2.4/postgis/lwgeom_functions_basic.c	2017-10-18 19:28:28 UTC (rev 16014)
@@ -2060,8 +2060,6 @@
 	LWPOLY *poly;
 	GSERIALIZED *result;
-	POINTARRAY **pa;
-	POINT4D p;
 	double x1, y1, x2, y2;
 	int srid = SRID_UNKNOWN;
Modified: branches/2.4/postgis/mvt.c
--- branches/2.4/postgis/mvt.c	2017-10-18 18:46:27 UTC (rev 16013)
+++ branches/2.4/postgis/mvt.c	2017-10-18 19:28:28 UTC (rev 16014)
@@ -478,7 +478,6 @@
 static void parse_datum_as_string(struct mvt_agg_context *ctx, Oid typoid,
 	Datum datum, uint32_t *tags, uint32_t k)
-	struct mvt_kv_string_value *kv;
 	Oid foutoid;
 	bool typisvarlena;
 	char *value;
@@ -667,11 +666,9 @@
 	double width = gbox->xmax - gbox->xmin;
 	double height = gbox->ymax - gbox->ymin;
 	double resx = width / extent;
-	double resy = height / extent;
 	double fx = extent / width;
 	double fy = -(extent / height);
 	double buffer_map_xunits = resx * buffer;
-	double buffer_map_yunits = resy * buffer;
 	const GBOX *ggbox;
 	POSTGIS_DEBUG(2, "mvt_geom called");
@@ -812,7 +809,6 @@
 	LWGEOM *lwgeom;
 	VectorTile__Tile__Feature *feature;
 	VectorTile__Tile__Layer *layer = ctx->layer;
-	VectorTile__Tile__Feature **features = layer->features;
 	POSTGIS_DEBUG(2, "mvt_agg_transfn called");
 	if (layer->n_features >= ctx->features_capacity) {
