[postgis-tickets] r16020 - Fix memory leak in lwgeom_grid_in_place
Paul Ramsey
pramsey at cleverelephant.ca
Fri Oct 20 06:58:00 PDT 2017
Author: pramsey
Date: 2017-10-20 06:58:00 -0700 (Fri, 20 Oct 2017)
New Revision: 16020
trunk/liblwgeom/lwgeom.c
>From Ra?\195?\186l Mar?\195?\173n Rodr?\195?\173guez
Closes #3910
Modified: trunk/liblwgeom/lwgeom.c
--- trunk/liblwgeom/lwgeom.c 2017-10-20 13:07:21 UTC (rev 16019)
+++ trunk/liblwgeom/lwgeom.c 2017-10-20 13:58:00 UTC (rev 16020)
@@ -2151,25 +2151,39 @@
case POLYGONTYPE:
LWPOLY *ply = (LWPOLY*)(geom);
- int i, j = 0;
if (!ply->rings) return;
- for (i = 0; i < ply->nrings; i++)
+ /* Check first the external ring */
+ int i = 0;
+ POINTARRAY *pa = ply->rings[0];
+ ptarray_grid_in_place(pa, grid);
+ if (pa->npoints < 4)
+ /* External ring collapsed: free everything */
+ for (i = 0; i < ply->nrings; i++)
+ ptarray_free(ply->rings[i]);
+ ply->nrings = 0;
+ return;
+ /* Check the other rings */
+ int j = 1;
+ for (i = 1; i < ply->nrings; i++)
POINTARRAY *pa = ply->rings[i];
/* Skip bad rings */
- if (pa->npoints < 4)
+ if (pa->npoints >= 4)
+ j++;
+ else
ptarray_free(pa);
- /* When internal rings collapse, we free */
- /* then and move on */
- if (i) continue;
- /* If external ring collapses, we free */
- /* it and stop processing */
- else break;
- /* Fill in just the rings we are keeping */
- ply->rings[j++] = pa;
/* Adjust ring count appropriately */
ply->nrings = j;
