[postgis-tickets] [PostGIS] #3912: glibtoolize doesn't install install-sh
trac at osgeo.org
Fri Oct 20 12:42:49 PDT 2017
Reporter: pramsey | Owner: strk
Type: defect | Status: assigned
Priority: medium | Milestone: PostGIS 2.4.2
Component: postgis | Version: 2.4.x
Resolution: | Keywords:
Comment (by strk):
The HOWTO_RELEASE file seems to prescribe testing the build after tarball
is made:
- Run: sh make_dist.sh $rev (or use debbie for this)
- Build and test generated tarball (including extension upgrade)
Should it be more explicit in recommending _not_ to run ./autogen.sh ?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3912#comment:3>
