[postgis-tickets] r16029 - Put build AUX files under build-aux
Sandro Santilli strk at kbt.io
Sat Oct 21 02:02:18 PDT 2017
Author: strk
Date: 2017-10-21 02:02:17 -0700 (Sat, 21 Oct 2017)
New Revision: 16029
Removed:
   branches/2.4/raster/install-sh
   branches/2.4/.gitignore
   branches/2.4/GNUmakefile.in
   branches/2.4/configure.ac
   branches/2.4/liblwgeom/Makefile.in
   branches/2.4/loader/Makefile.in
   branches/2.4/raster/loader/Makefile.in
   branches/2.4/utils/Makefile.in
Cleans and ignore build aux files from new location,
and remove spurious install-sh from repository.
References #3912 for 2.4 branch
Modified: branches/2.4/.gitignore
--- branches/2.4/.gitignore	2017-10-21 07:45:47 UTC (rev 16028)
+++ branches/2.4/.gitignore	2017-10-21 09:02:17 UTC (rev 16029)
@@ -11,14 +11,11 @@
 *.gcda
 *.gcno
 gmon.out
-install-sh
 postgis_svn_revision.h
 aclocal.m4
 autom4te.cache/
-config.guess
 config.log
 config.status
-config.sub
 configure
 doc/html/image_src/generator
@@ -87,6 +84,7 @@
 loader/shp2pgsql
 loader/shp2pgsql-gui
 ltmain.sh
+build-aux/
 macros/libtool.m4
 macros/lt~obsolete.m4
 macros/ltoptions.m4
Modified: branches/2.4/GNUmakefile.in
--- branches/2.4/GNUmakefile.in	2017-10-21 07:45:47 UTC (rev 16028)
+++ branches/2.4/GNUmakefile.in	2017-10-21 09:02:17 UTC (rev 16029)
@@ -58,8 +58,7 @@
 maintainer-clean-local: distclean-local
 	rm -f configure
-	rm -f config.guess config.rpath config.sub
-	rm -f libtool install-sh ltmain.sh
+	rm -Rf build-aux
 maintainer-clean:
 	@echo '------------------------------------------------------'
Modified: branches/2.4/configure.ac
--- branches/2.4/configure.ac	2017-10-21 07:45:47 UTC (rev 16028)
+++ branches/2.4/configure.ac	2017-10-21 09:02:17 UTC (rev 16029)
@@ -12,8 +12,8 @@
 AC_INIT()
 AC_CONFIG_HEADERS([postgis_config.h])
 AC_CONFIG_MACRO_DIR([macros])
+AC_CONFIG_AUX_DIR([build-aux])
 dnl Invoke libtool: we do this as it is the easiest way to find the PIC
 dnl flags required to build liblwgeom
 AC_PROG_LIBTOOL
Modified: branches/2.4/liblwgeom/Makefile.in
--- branches/2.4/liblwgeom/Makefile.in	2017-10-21 07:45:47 UTC (rev 16028)
+++ branches/2.4/liblwgeom/Makefile.in	2017-10-21 09:02:17 UTC (rev 16029)
@@ -33,7 +33,7 @@
 libdir = @libdir@
 includedir = @includedir@
 SHELL = @SHELL@
-INSTALL = $(SHELL) ../install-sh
+INSTALL = @INSTALL@
 LIBTOOL = @LIBTOOL@
 SOVER = @POSTGIS_MAJOR_VERSION at .@POSTGIS_MINOR_VERSION@
Modified: branches/2.4/loader/Makefile.in
--- branches/2.4/loader/Makefile.in	2017-10-21 07:45:47 UTC (rev 16028)
+++ branches/2.4/loader/Makefile.in	2017-10-21 09:02:17 UTC (rev 16029)
@@ -25,7 +25,7 @@
 CFLAGS=-I ../liblwgeom @CFLAGS@ @PICFLAGS@ @WARNFLAGS@ @PROJ_CPPFLAGS@
 top_builddir = @top_builddir@
 SHELL = @SHELL@
 LIBTOOL = @LIBTOOL@
 # Filenames with extension as determined by the OS
Deleted: branches/2.4/raster/install-sh
--- branches/2.4/raster/install-sh	2017-10-21 07:45:47 UTC (rev 16028)
+++ branches/2.4/raster/install-sh	2017-10-21 09:02:17 UTC (rev 16029)
@@ -1,325 +0,0 @@
-#!/bin/sh
-# install - install a program, script, or datafile
-scriptversion=2004-04-01.17
-# This originates from X11R5 (mit/util/scripts/install.sh), which was
-# later released in X11R6 (xc/config/util/install.sh) with the
-# following copyright and license.
-# Copyright (C) 1994 X Consortium
-# Permission is hereby granted, free of charge, to any person obtaining a copy
-# of this software and associated documentation files (the "Software"), to
-# deal in the Software without restriction, including without limitation the
-# rights to use, copy, modify, merge, publish, distribute, sublicense, and/or
-# sell copies of the Software, and to permit persons to whom the Software is
-# furnished to do so, subject to the following conditions:
-# The above copyright notice and this permission notice shall be included in
-# all copies or substantial portions of the Software.
-# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
-# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
-# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.  IN NO EVENT SHALL THE
-# X CONSORTIUM BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN
-# AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNEC-
-# TION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
-# Except as contained in this notice, the name of the X Consortium shall not
-# be used in advertising or otherwise to promote the sale, use or other deal-
-# ings in this Software without prior written authorization from the X Consor-
-# tium.
-# FSF changes to this file are in the public domain.
-# Calling this script install-sh is preferred over install.sh, to prevent
-# `make' implicit rules from creating a file called install from it
-# when there is no Makefile.
-# This script is compatible with the BSD install script, but was written
-# from scratch.  It can only install one file at a time, a restriction
-# shared with many OS's install programs.
-# set DOITPROG to echo to test this script
-# Don't use :- since 4.3BSD and earlier shells don't like it.
-doit="${DOITPROG-}"
-# put in absolute paths if you don't have them in your path; or use env. vars.
-mvprog="${MVPROG-mv}"
-cpprog="${CPPROG-cp}"
-chmodprog="${CHMODPROG-chmod}"
-chownprog="${CHOWNPROG-chown}"
-chgrpprog="${CHGRPPROG-chgrp}"
-stripprog="${STRIPPROG-strip}"
-rmprog="${RMPROG-rm}"
-mkdirprog="${MKDIRPROG-mkdir}"
-transformbasename=
-transform_arg=
-instcmd="$mvprog"
-chmodcmd="$chmodprog 0755"
-chowncmd=
-chgrpcmd=
-stripcmd=
-rmcmd="$rmprog -f"
-mvcmd="$mvprog"
-src=
-dst=
-dir_arg=
-usage="Usage: $0 [OPTION]... SRCFILE DSTFILE
-   or: $0 [OPTION]... SRCFILES... DIRECTORY
-   or: $0 -d DIRECTORIES...
-In the first form, install SRCFILE to DSTFILE, removing SRCFILE by default.
-In the second, create the directory path DIR.
-Options:
--b=TRANSFORMBASENAME
--c         copy source (using $cpprog) instead of moving (using $mvprog).
--d         create directories instead of installing files.
--g GROUP   $chgrp installed files to GROUP.
--m MODE    $chmod installed files to MODE.
--o USER    $chown installed files to USER.
--s         strip installed files (using $stripprog).
--t=TRANSFORM
---help     display this help and exit.
---version  display version info and exit.
-Environment variables override the default commands:
-  CHGRPPROG CHMODPROG CHOWNPROG CPPROG MKDIRPROG MVPROG RMPROG STRIPPROG
-while test -n "$1"; do
-  case $1 in
-    -b=*) transformbasename=`echo $1 | sed 's/-b=//'`
-        shift
-        continue;;
-    -c) instcmd=$cpprog
-        shift
-        continue;;
-    -d) dir_arg=true
-        shift
-        continue;;
-    -g) chgrpcmd="$chgrpprog $2"
-        shift
-        shift
-        continue;;
-    --help) echo "$usage"; exit 0;;
-    -m) chmodcmd="$chmodprog $2"
-        shift
-        shift
-        continue;;
-    -o) chowncmd="$chownprog $2"
-        shift
-        shift
-        continue;;
-    -s) stripcmd=$stripprog
-        shift
-        continue;;
-    -t=*) transformarg=`echo $1 | sed 's/-t=//'`
-        shift
-        continue;;
-    --version) echo "$0 $scriptversion"; exit 0;;
-    *)  # When -d is used, all remaining arguments are directories to create.
-	test -n "$dir_arg" && break
-        # Otherwise, the last argument is the destination.  Remove it from $@.
-	for arg
-	do
-          if test -n "$dstarg"; then
-	    # $@ is not empty: it contains at least $arg.
-	    set fnord "$@" "$dstarg"
-	    shift # fnord
-	  fi
-	  shift # arg
-	  dstarg=$arg
-	done
-	break;;
-  esac
-done
-if test -z "$1"; then
-  if test -z "$dir_arg"; then
-    echo "$0: no input file specified." >&2
-    exit 1
-  fi
-  # It's OK to call `install-sh -d' without argument.
-  # This can happen when creating conditional directories.
-  exit 0
-fi
-for src
-do
-  # Protect names starting with `-'.
-  case $src in
-    -*) src=./$src ;;
-  esac
-  if test -n "$dir_arg"; then
-    dst=$src
-    src=
-    if test -d "$dst"; then
-      instcmd=:
-      chmodcmd=
-    else
-      instcmd=$mkdirprog
-    fi
-  else
-    # Waiting for this to be detected by the "$instcmd $src $dsttmp" command
-    # might cause directories to be created, which would be especially bad
-    # if $src (and thus $dsttmp) contains '*'.
-    if test ! -f "$src" && test ! -d "$src"; then
-      echo "$0: $src does not exist." >&2
-      exit 1
-    fi
-    if test -z "$dstarg"; then
-      echo "$0: no destination specified." >&2
-      exit 1
-    fi
-    dst=$dstarg
-    case $dst in
-      -*) dst=./$dst ;;
-    esac
-    # If destination is a directory, append the input filename; won't work
-    # if double slashes aren't ignored.
-      dst=$dst/`basename "$src"`
-    fi
-  fi
-  # This sed command emulates the dirname command.
-  dstdir=`echo "$dst" | sed -e 's,[^/]*$,,;s,/$,,;s,^$,.,'`
-  # Make sure that the destination directory exists.
-  # Skip lots of stat calls in the usual case.
-  if test ! -d "$dstdir"; then
-    defaultIFS='
-    IFS="${IFS-$defaultIFS}"
-    oIFS=$IFS
-    # Some sh's can't handle IFS=/ for some reason.
-    IFS='%'
-    set - `echo "$dstdir" | sed -e 's@/@%@g' -e 's@^%@/@'`
-    IFS=$oIFS
-    pathcomp=
-    while test $# -ne 0 ; do
-      pathcomp=$pathcomp$1
-      shift
-      if test ! -d "$pathcomp"; then
-        $mkdirprog "$pathcomp" || lasterr=$?
-	# mkdir can fail with a `File exist' error in case several
-	# install-sh are creating the directory concurrently.  This
-	# is OK.
-	test ! -d "$pathcomp" && { (exit ${lasterr-1}); exit; }
-      fi
-      pathcomp=$pathcomp/
-    done
-  fi
-    $doit $instcmd "$dst" \
-      && { test -z "$chowncmd" || $doit $chowncmd "$dst"; } \
-      && { test -z "$chgrpcmd" || $doit $chgrpcmd "$dst"; } \
-      && { test -z "$stripcmd" || $doit $stripcmd "$dst"; } \
-      && { test -z "$chmodcmd" || $doit $chmodcmd "$dst"; }
-  else
-    # If we're going to rename the final executable, determine the name now.
-    if test -z "$transformarg"; then
-      dstfile=`basename "$dst"`
-    else
-      dstfile=`basename "$dst" $transformbasename \
-               | sed $transformarg`$transformbasename
-    fi
-    # don't allow the sed command to completely eliminate the filename.
-    test -z "$dstfile" && dstfile=`basename "$dst"`
-    # Make a couple of temp file names in the proper directory.
-    dsttmp=$dstdir/_inst.$$_
-    rmtmp=$dstdir/_rm.$$_
-    # Trap to clean up those temp files at exit.
-    trap 'status=$?; rm -f "$dsttmp" "$rmtmp" && exit $status' 0
-    trap '(exit $?); exit' 1 2 13 15
-    # Move or copy the file name to the temp name
-    $doit $instcmd "$src" "$dsttmp" &&
-    # and set any options; do chmod last to preserve setuid bits.
-    # If any of these fail, we abort the whole thing.  If we want to
-    # ignore errors from any of these, just make sure not to ignore
-    # errors from the above "$doit $instcmd $src $dsttmp" command.
-    { test -z "$chowncmd" || $doit $chowncmd "$dsttmp"; } \
-      && { test -z "$chgrpcmd" || $doit $chgrpcmd "$dsttmp"; } \
-      && { test -z "$stripcmd" || $doit $stripcmd "$dsttmp"; } \
-      && { test -z "$chmodcmd" || $doit $chmodcmd "$dsttmp"; } &&
-    # Now rename the file to the real destination.
-    { $doit $mvcmd -f "$dsttmp" "$dstdir/$dstfile" 2>/dev/null \
-	   # The rename failed, perhaps because mv can't rename something else
-	   # to itself, or perhaps because mv is so ancient that it does not
-	   # support -f.
-	   # Now remove or move aside any old file at destination location.
-	   # We try this two ways since rm can't unlink itself on some
-	   # systems and the destination file might be busy for other
-	   # reasons.  In this case, the final cleanup might fail but the new
-	   # file should still install successfully.
-	     if test -f "$dstdir/$dstfile"; then
-	       $doit $rmcmd -f "$dstdir/$dstfile" 2>/dev/null \
-	       || $doit $mvcmd -f "$dstdir/$dstfile" "$rmtmp" 2>/dev/null \
-		 echo "$0: cannot unlink or rename $dstdir/$dstfile" >&2
-		 (exit 1); exit
-	     else
-	     fi
-	   $doit $mvcmd "$dsttmp" "$dstdir/$dstfile"
-  fi || { (exit 1); exit; }
-done
-# The final little trick to "correctly" pass the exit status to the exit trap.
-  (exit 0); exit
-# Local variables:
-# eval: (add-hook 'write-file-hooks 'time-stamp)
-# time-stamp-start: "scriptversion="
-# time-stamp-format: "%:y-%02m-%02d.%02H"
-# time-stamp-end: "$"
-# End:
Modified: branches/2.4/raster/loader/Makefile.in
--- branches/2.4/raster/loader/Makefile.in	2017-10-21 07:45:47 UTC (rev 16028)
+++ branches/2.4/raster/loader/Makefile.in	2017-10-21 09:02:17 UTC (rev 16029)
@@ -21,11 +21,11 @@
 # Set CFLAGS after PGXS, otherwise it will get overwritten with the PGXS
-# version which is not what we want.
+# version which is not what we want.
 CC=@CC@
 SHELL = @SHELL@
-INSTALL = $(SHELL) ../../install-sh
 LIBTOOL = @LIBTOOL@
Modified: branches/2.4/utils/Makefile.in
--- branches/2.4/utils/Makefile.in	2017-10-21 07:45:47 UTC (rev 16028)
+++ branches/2.4/utils/Makefile.in	2017-10-21 09:02:17 UTC (rev 16029)
@@ -21,12 +21,12 @@
 DATA_built=postgis_restore.pl
 # PGXS information
-PG_CONFIG = @PG_CONFIG@
+PG_CONFIG = @PG_CONFIG@
 PGXS := @PGXS@
 include $(PGXS)
 SHELL = @SHELL@
 SCRIPTS_built = postgis_restore.pl
