[postgis-tickets] r16031 - Put build AUX files under build-aux
Sandro Santilli
strk at kbt.io
Sat Oct 21 02:08:32 PDT 2017
Author: strk
Date: 2017-10-21 02:08:32 -0700 (Sat, 21 Oct 2017)
New Revision: 16031
Removed:
branches/2.2/raster/install-sh
branches/2.2/.gitignore
branches/2.2/GNUmakefile.in
branches/2.2/configure.ac
branches/2.2/liblwgeom/Makefile.in
branches/2.2/loader/Makefile.in
branches/2.2/raster/loader/Makefile.in
branches/2.2/utils/Makefile.in
Cleans and ignore build aux files from new location,
and remove spurious install-sh from repository.
Closes #3912 in 2.2 branch
Modified: branches/2.2/.gitignore
--- branches/2.2/.gitignore 2017-10-21 09:04:58 UTC (rev 16030)
+++ branches/2.2/.gitignore 2017-10-21 09:08:32 UTC (rev 16031)
@@ -3,14 +3,11 @@
.libs
*.lo
gmon.out
-install-sh
postgis_svn_revision.h
aclocal.m4
autom4te.cache/
-config.guess
config.log
config.status
-config.sub
configure
doc/html/image_src/generator
@@ -79,6 +76,7 @@
loader/shp2pgsql
loader/shp2pgsql-gui
ltmain.sh
+build-aux/
macros/libtool.m4
macros/lt~obsolete.m4
macros/ltoptions.m4
Modified: branches/2.2/GNUmakefile.in
--- branches/2.2/GNUmakefile.in 2017-10-21 09:04:58 UTC (rev 16030)
+++ branches/2.2/GNUmakefile.in 2017-10-21 09:08:32 UTC (rev 16031)
@@ -50,6 +50,8 @@
rm -f java/jdbc/Makefile
maintainer-clean-local: distclean-local
+ rm -f configure
+ rm -Rf build-aux
maintainer-clean:
@echo '------------------------------------------------------'
@@ -61,7 +63,6 @@
$(MAKE) -C liblwgeom maintainer-clean
$(MAKE) -C java/jdbc maintainer-clean
$(MAKE) maintainer-clean-local
- rm -f configure
garden:
Modified: branches/2.2/configure.ac
--- branches/2.2/configure.ac 2017-10-21 09:04:58 UTC (rev 16030)
+++ branches/2.2/configure.ac 2017-10-21 09:08:32 UTC (rev 16031)
@@ -12,8 +12,8 @@
AC_INIT()
AC_CONFIG_HEADERS([postgis_config.h])
AC_CONFIG_MACRO_DIR([macros])
+AC_CONFIG_AUX_DIR([build-aux])
dnl Invoke libtool: we do this as it is the easiest way to find the PIC
dnl flags required to build liblwgeom
AC_PROG_LIBTOOL
Modified: branches/2.2/liblwgeom/Makefile.in
--- branches/2.2/liblwgeom/Makefile.in 2017-10-21 09:04:58 UTC (rev 16030)
+++ branches/2.2/liblwgeom/Makefile.in 2017-10-21 09:08:32 UTC (rev 16031)
@@ -20,7 +20,7 @@
libdir = @libdir@
includedir = @includedir@
SHELL = @SHELL@
-INSTALL = $(SHELL) ../install-sh
+INSTALL = @INSTALL@
LIBTOOL = @LIBTOOL@
SOVER = @POSTGIS_MAJOR_VERSION at .@POSTGIS_MINOR_VERSION@
Modified: branches/2.2/loader/Makefile.in
--- branches/2.2/loader/Makefile.in 2017-10-21 09:04:58 UTC (rev 16030)
+++ branches/2.2/loader/Makefile.in 2017-10-21 09:08:32 UTC (rev 16031)
@@ -25,7 +25,7 @@
CFLAGS=-I ../liblwgeom @CFLAGS@ @PICFLAGS@ @WARNFLAGS@ @PROJ_CPPFLAGS@
top_builddir = @top_builddir@
SHELL = @SHELL@
LIBTOOL = @LIBTOOL@
# Filenames with extension as determined by the OS
Deleted: branches/2.2/raster/install-sh
--- branches/2.2/raster/install-sh 2017-10-21 09:04:58 UTC (rev 16030)
+++ branches/2.2/raster/install-sh 2017-10-21 09:08:32 UTC (rev 16031)
@@ -1,325 +0,0 @@
-#!/bin/sh
-# install - install a program, script, or datafile
-scriptversion=2004-04-01.17
-# This originates from X11R5 (mit/util/scripts/install.sh), which was
-# later released in X11R6 (xc/config/util/install.sh) with the
-# following copyright and license.
-# Copyright (C) 1994 X Consortium
-# Permission is hereby granted, free of charge, to any person obtaining a copy
-# of this software and associated documentation files (the "Software"), to
-# deal in the Software without restriction, including without limitation the
-# rights to use, copy, modify, merge, publish, distribute, sublicense, and/or
-# sell copies of the Software, and to permit persons to whom the Software is
-# furnished to do so, subject to the following conditions:
-# The above copyright notice and this permission notice shall be included in
-# all copies or substantial portions of the Software.
-# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
-# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
-# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
-# X CONSORTIUM BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN
-# AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNEC-
-# TION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
-# Except as contained in this notice, the name of the X Consortium shall not
-# be used in advertising or otherwise to promote the sale, use or other deal-
-# ings in this Software without prior written authorization from the X Consor-
-# tium.
-# FSF changes to this file are in the public domain.
-# Calling this script install-sh is preferred over install.sh, to prevent
-# `make' implicit rules from creating a file called install from it
-# when there is no Makefile.
-# This script is compatible with the BSD install script, but was written
-# from scratch. It can only install one file at a time, a restriction
-# shared with many OS's install programs.
-# set DOITPROG to echo to test this script
-# Don't use :- since 4.3BSD and earlier shells don't like it.
-doit="${DOITPROG-}"
-# put in absolute paths if you don't have them in your path; or use env. vars.
-mvprog="${MVPROG-mv}"
-cpprog="${CPPROG-cp}"
-chmodprog="${CHMODPROG-chmod}"
-chownprog="${CHOWNPROG-chown}"
-chgrpprog="${CHGRPPROG-chgrp}"
-stripprog="${STRIPPROG-strip}"
-rmprog="${RMPROG-rm}"
-mkdirprog="${MKDIRPROG-mkdir}"
-transformbasename=
-transform_arg=
-instcmd="$mvprog"
-chmodcmd="$chmodprog 0755"
-chowncmd=
-chgrpcmd=
-stripcmd=
-rmcmd="$rmprog -f"
-mvcmd="$mvprog"
-src=
-dst=
-dir_arg=
-usage="Usage: $0 [OPTION]... SRCFILE DSTFILE
- or: $0 [OPTION]... SRCFILES... DIRECTORY
- or: $0 -d DIRECTORIES...
-In the first form, install SRCFILE to DSTFILE, removing SRCFILE by default.
-In the second, create the directory path DIR.
-Options:
--b=TRANSFORMBASENAME
--c copy source (using $cpprog) instead of moving (using $mvprog).
--d create directories instead of installing files.
--g GROUP $chgrp installed files to GROUP.
--m MODE $chmod installed files to MODE.
--o USER $chown installed files to USER.
--s strip installed files (using $stripprog).
--t=TRANSFORM
---help display this help and exit.
---version display version info and exit.
-Environment variables override the default commands:
- CHGRPPROG CHMODPROG CHOWNPROG CPPROG MKDIRPROG MVPROG RMPROG STRIPPROG
-while test -n "$1"; do
- case $1 in
- -b=*) transformbasename=`echo $1 | sed 's/-b=//'`
- shift
- continue;;
- -c) instcmd=$cpprog
- shift
- continue;;
- -d) dir_arg=true
- shift
- continue;;
- -g) chgrpcmd="$chgrpprog $2"
- shift
- shift
- continue;;
- --help) echo "$usage"; exit 0;;
- -m) chmodcmd="$chmodprog $2"
- shift
- shift
- continue;;
- -o) chowncmd="$chownprog $2"
- shift
- shift
- continue;;
- -s) stripcmd=$stripprog
- shift
- continue;;
- -t=*) transformarg=`echo $1 | sed 's/-t=//'`
- shift
- continue;;
- --version) echo "$0 $scriptversion"; exit 0;;
- *) # When -d is used, all remaining arguments are directories to create.
- test -n "$dir_arg" && break
- # Otherwise, the last argument is the destination. Remove it from $@.
- for arg
- do
- if test -n "$dstarg"; then
- # $@ is not empty: it contains at least $arg.
- set fnord "$@" "$dstarg"
- shift # fnord
- fi
- shift # arg
- dstarg=$arg
- done
- break;;
- esac
-done
-if test -z "$1"; then
- if test -z "$dir_arg"; then
- echo "$0: no input file specified." >&2
- exit 1
- fi
- # It's OK to call `install-sh -d' without argument.
- # This can happen when creating conditional directories.
- exit 0
-fi
-for src
-do
- # Protect names starting with `-'.
- case $src in
- -*) src=./$src ;;
- esac
- if test -n "$dir_arg"; then
- dst=$src
- src=
- if test -d "$dst"; then
- instcmd=:
- chmodcmd=
- else
- instcmd=$mkdirprog
- fi
- else
- # Waiting for this to be detected by the "$instcmd $src $dsttmp" command
- # might cause directories to be created, which would be especially bad
- # if $src (and thus $dsttmp) contains '*'.
- if test ! -f "$src" && test ! -d "$src"; then
- echo "$0: $src does not exist." >&2
- exit 1
- fi
- if test -z "$dstarg"; then
- echo "$0: no destination specified." >&2
- exit 1
- fi
- dst=$dstarg
- case $dst in
- -*) dst=./$dst ;;
- esac
- # If destination is a directory, append the input filename; won't work
- # if double slashes aren't ignored.
- dst=$dst/`basename "$src"`
- fi
- fi
- # This sed command emulates the dirname command.
- dstdir=`echo "$dst" | sed -e 's,[^/]*$,,;s,/$,,;s,^$,.,'`
- # Make sure that the destination directory exists.
- # Skip lots of stat calls in the usual case.
- if test ! -d "$dstdir"; then
- defaultIFS='
- IFS="${IFS-$defaultIFS}"
- oIFS=$IFS
- # Some sh's can't handle IFS=/ for some reason.
- IFS='%'
- set - `echo "$dstdir" | sed -e 's@/@%@g' -e 's@^%@/@'`
- IFS=$oIFS
- pathcomp=
- while test $# -ne 0 ; do
- pathcomp=$pathcomp$1
- shift
- if test ! -d "$pathcomp"; then
- $mkdirprog "$pathcomp" || lasterr=$?
- # mkdir can fail with a `File exist' error in case several
- # install-sh are creating the directory concurrently. This
- # is OK.
- test ! -d "$pathcomp" && { (exit ${lasterr-1}); exit; }
- fi
- pathcomp=$pathcomp/
- done
- fi
- $doit $instcmd "$dst" \
- && { test -z "$chowncmd" || $doit $chowncmd "$dst"; } \
- && { test -z "$chgrpcmd" || $doit $chgrpcmd "$dst"; } \
- && { test -z "$stripcmd" || $doit $stripcmd "$dst"; } \
- && { test -z "$chmodcmd" || $doit $chmodcmd "$dst"; }
- else
- # If we're going to rename the final executable, determine the name now.
- if test -z "$transformarg"; then
- dstfile=`basename "$dst"`
- else
- dstfile=`basename "$dst" $transformbasename \
- | sed $transformarg`$transformbasename
- fi
- # don't allow the sed command to completely eliminate the filename.
- test -z "$dstfile" && dstfile=`basename "$dst"`
- # Make a couple of temp file names in the proper directory.
- dsttmp=$dstdir/_inst.$$_
- rmtmp=$dstdir/_rm.$$_
- # Trap to clean up those temp files at exit.
- trap 'status=$?; rm -f "$dsttmp" "$rmtmp" && exit $status' 0
- trap '(exit $?); exit' 1 2 13 15
- # Move or copy the file name to the temp name
- $doit $instcmd "$src" "$dsttmp" &&
- # and set any options; do chmod last to preserve setuid bits.
- # If any of these fail, we abort the whole thing. If we want to
- # ignore errors from any of these, just make sure not to ignore
- # errors from the above "$doit $instcmd $src $dsttmp" command.
- { test -z "$chowncmd" || $doit $chowncmd "$dsttmp"; } \
- && { test -z "$chgrpcmd" || $doit $chgrpcmd "$dsttmp"; } \
- && { test -z "$stripcmd" || $doit $stripcmd "$dsttmp"; } \
- && { test -z "$chmodcmd" || $doit $chmodcmd "$dsttmp"; } &&
- # Now rename the file to the real destination.
- { $doit $mvcmd -f "$dsttmp" "$dstdir/$dstfile" 2>/dev/null \
- # The rename failed, perhaps because mv can't rename something else
- # to itself, or perhaps because mv is so ancient that it does not
- # support -f.
- # Now remove or move aside any old file at destination location.
- # We try this two ways since rm can't unlink itself on some
- # systems and the destination file might be busy for other
- # reasons. In this case, the final cleanup might fail but the new
- # file should still install successfully.
- if test -f "$dstdir/$dstfile"; then
- $doit $rmcmd -f "$dstdir/$dstfile" 2>/dev/null \
- || $doit $mvcmd -f "$dstdir/$dstfile" "$rmtmp" 2>/dev/null \
- echo "$0: cannot unlink or rename $dstdir/$dstfile" >&2
- (exit 1); exit
- else
- fi
- $doit $mvcmd "$dsttmp" "$dstdir/$dstfile"
- fi || { (exit 1); exit; }
-done
-# The final little trick to "correctly" pass the exit status to the exit trap.
- (exit 0); exit
-# Local variables:
-# eval: (add-hook 'write-file-hooks 'time-stamp)
-# time-stamp-start: "scriptversion="
-# time-stamp-format: "%:y-%02m-%02d.%02H"
-# time-stamp-end: "$"
-# End:
Modified: branches/2.2/raster/loader/Makefile.in
--- branches/2.2/raster/loader/Makefile.in 2017-10-21 09:04:58 UTC (rev 16030)
+++ branches/2.2/raster/loader/Makefile.in 2017-10-21 09:08:32 UTC (rev 16031)
@@ -21,11 +21,11 @@
# Set CFLAGS after PGXS, otherwise it will get overwritten with the PGXS
-# version which is not what we want.
+# version which is not what we want.
CC=@CC@
SHELL = @SHELL@
-INSTALL = $(SHELL) ../../install-sh
LIBTOOL = @LIBTOOL@
Modified: branches/2.2/utils/Makefile.in
--- branches/2.2/utils/Makefile.in 2017-10-21 09:04:58 UTC (rev 16030)
+++ branches/2.2/utils/Makefile.in 2017-10-21 09:08:32 UTC (rev 16031)
@@ -21,12 +21,12 @@
DATA_built=postgis_restore.pl
# PGXS information
-PG_CONFIG = @PG_CONFIG@
+PG_CONFIG = @PG_CONFIG@
PGXS := @PGXS@
include $(PGXS)
SHELL = @SHELL@
SCRIPTS_built = postgis_restore.pl
