[postgis-tickets] r16034 - Use minimum tolerance when adding pre-snapped edge endpoints
Sandro Santilli strk at kbt.io
Sun Oct 22 08:38:54 PDT 2017
Author: strk
Date: 2017-10-22 08:38:54 -0700 (Sun, 22 Oct 2017)
New Revision: 16034
   trunk/liblwgeom/lwgeom_topo.c
Modified: trunk/liblwgeom/lwgeom_topo.c
--- trunk/liblwgeom/lwgeom_topo.c	2017-10-22 15:38:47 UTC (rev 16033)
+++ trunk/liblwgeom/lwgeom_topo.c	2017-10-22 15:38:54 UTC (rev 16034)
@@ -5000,6 +5000,25 @@
 /* Return the smallest delta that can perturbate
+ * the given value */
+static inline double
+_lwt_minToleranceDouble( double d )
+  double ret = 3.6 * pow(10,  - ( 15 - log10(d?d:1.0) ) );
+  return ret;
+/* Return the smallest delta that can perturbate
+ * the given point */
+_lwt_minTolerancePoint2d( const POINT2D* p )
+  double max = FP_ABS(p->x);
+  if ( max < FP_ABS(p->y) ) max = FP_ABS(p->y);
+  return _lwt_minToleranceDouble(max);
  * the maximum absolute value of a geometry ordinate
 static double
@@ -5016,7 +5035,7 @@
   if ( max < FP_ABS(gbox->ymin) ) max = FP_ABS(gbox->ymin);
   if ( max < FP_ABS(gbox->ymax) ) max = FP_ABS(gbox->ymax);
-  ret = 3.6 * pow(10,  - ( 15 - log10(max?max:1.0) ) );
+  ret = _lwt_minToleranceDouble(max);
   return ret;
@@ -5486,7 +5505,9 @@
     lwnotice("Empty component of noded line");
     return 0; /* must be empty */
-  nid[0] = _lwt_AddPoint( topo, start_point, tol, handleFaceSplit );
+  nid[0] = _lwt_AddPoint( topo, start_point,
+                          _lwt_minTolerance(lwpoint_as_lwgeom(start_point)),
+                          handleFaceSplit );
   lwpoint_free(start_point); /* too late if lwt_AddPoint calls lwerror */
   if ( nid[0] == -1 ) return -1; /* lwerror should have been called */
@@ -5497,7 +5518,9 @@
             "after successfully getting first point !?");
     return -1;
-  nid[1] = _lwt_AddPoint( topo, end_point, tol, handleFaceSplit );
+  nid[1] = _lwt_AddPoint( topo, end_point,
+                          _lwt_minTolerance(lwpoint_as_lwgeom(end_point)),
   lwpoint_free(end_point); /* too late if lwt_AddPoint calls lwerror */
   if ( nid[1] == -1 ) return -1; /* lwerror should have been called */
