[postgis-tickets] r16045 - Replace the 3 ST_CurveToLine signatures with a single one
Sandro Santilli
strk at kbt.io
Sun Oct 22 10:54:09 PDT 2017
Author: strk
Date: 2017-10-22 10:54:09 -0700 (Sun, 22 Oct 2017)
New Revision: 16045
trunk/doc/reference_processing.xml
trunk/postgis/postgis.sql.in
trunk/postgis/postgis_drop_before.sql
The new one uses defaults for arguments
Modified: trunk/doc/reference_processing.xml
--- trunk/doc/reference_processing.xml 2017-10-22 17:40:18 UTC (rev 16044)
+++ trunk/doc/reference_processing.xml 2017-10-22 17:54:09 UTC (rev 16045)
@@ -839,18 +839,9 @@
<funcprototype>
<funcdef>geometry <function>ST_CurveToLine</function></funcdef>
<paramdef><type>geometry</type> <parameter>curveGeom</parameter></paramdef>
- </funcprototype>
- <funcprototype>
- <funcdef>geometry <function>ST_CurveToLine</function></funcdef>
- <paramdef><type>geometry</type> <parameter>curveGeom</parameter></paramdef>
- <paramdef><type>integer</type> <parameter>segments_per_qtr_circle</parameter></paramdef>
- </funcprototype>
- <funcprototype>
<paramdef><type>float</type> <parameter>tolerance</parameter></paramdef>
- <paramdef><type>integer</type> <parameter>tolerance_type</parameter></paramdef>
- <paramdef><type>integer</type> <parameter>flags</parameter></paramdef>
+ <paramdef choice="opt"><type>integer</type> <parameter>tolerance_type</parameter></paramdef>
+ <paramdef choice="opt"><type>integer</type> <parameter>flags</parameter></paramdef>
</funcprototype>
</funcsynopsis>
</refsynopsisdiv>
Modified: trunk/postgis/postgis.sql.in
--- trunk/postgis/postgis.sql.in 2017-10-22 17:40:18 UTC (rev 16044)
+++ trunk/postgis/postgis.sql.in 2017-10-22 17:54:09 UTC (rev 16045)
@@ -5674,33 +5674,10 @@
-- Availability: 2.4.0
-CREATE OR REPLACE FUNCTION ST_CurveToLine(geom geometry, tol float8, toltype integer, flags integer)
+CREATE OR REPLACE FUNCTION ST_CurveToLine(geom geometry, tol float8 DEFAULT 32, toltype integer DEFAULT 0, flags integer DEFAULT 0)
RETURNS geometry
AS 'MODULE_PATHNAME', 'ST_CurveToLine'
LANGUAGE 'c' IMMUTABLE STRICT _PARALLEL;
--- SQL-MM
--- ST_CurveToLine(Geometry geometry, SegmentsPerQuarter integer)
--- Converts a given geometry to a linear geometry. Each curveed
--- geometry or segment is converted into a linear approximation using
--- the given number of segments per quarter circle.
-CREATE OR REPLACE FUNCTION ST_CurveToLine(geometry, integer)
- RETURNS geometry AS 'SELECT ST_CurveToLine($1, $2::float8, 0, 0)'
- LANGUAGE 'sql' IMMUTABLE STRICT _PARALLEL;
--- SQL-MM
--- the default value of 32 segments per quarter circle
-CREATE OR REPLACE FUNCTION ST_CurveToLine(geometry)
- RETURNS geometry AS 'SELECT ST_CurveToLine($1, 32::integer)'
CREATE OR REPLACE FUNCTION ST_HasArc(Geometry geometry)
RETURNS boolean
Modified: trunk/postgis/postgis_drop_before.sql
--- trunk/postgis/postgis_drop_before.sql 2017-10-22 17:40:18 UTC (rev 16044)
+++ trunk/postgis/postgis_drop_before.sql 2017-10-22 17:54:09 UTC (rev 16045)
@@ -73,5 +73,9 @@
DROP AGGREGATE IF EXISTS ST_AsGeobuf(text, anyelement);
DROP FUNCTION IF EXISTS pgis_asgeobuf_transfn(internal, text, anyelement);
DROP FUNCTION IF EXISTS pgis_asmvt_transfn(internal, text, int4, text, anyelement);
+-- Going from multiple functions to default args
+-- Need to drop old multiple variants to not get in trouble.
+DROP FUNCTION IF EXISTS ST_CurveToLine(geometry, integer);
+DROP FUNCTION IF EXISTS ST_CurveToLine(geometry);
DROP VIEW IF EXISTS geometry_columns; -- removed cast 2.2.0 so need to recreate
