[postgis-tickets] r16055 - Uninstall geocoder & topology extension upgrade paths on "make uninstall"
Sandro Santilli
strk at kbt.io
Sun Oct 22 14:32:19 PDT 2017
Author: strk
Date: 2017-10-22 14:32:19 -0700 (Sun, 22 Oct 2017)
New Revision: 16055
trunk/extensions/postgis_tiger_geocoder/Makefile.in
trunk/extensions/postgis_topology/Makefile.in
Modified: trunk/extensions/postgis_tiger_geocoder/Makefile.in
--- trunk/extensions/postgis_tiger_geocoder/Makefile.in 2017-10-22 21:30:16 UTC (rev 16054)
+++ trunk/extensions/postgis_tiger_geocoder/Makefile.in 2017-10-22 21:32:19 UTC (rev 16055)
@@ -226,6 +226,16 @@
ln -fs "$${tpl}" $(EXTDIR)/$(EXTENSION)--$$OLD_VERSION--$(EXTVERSION).sql; \
done
+uninstall: uninstall-upgrade-paths
+INSTALLED_UPGRADE_SCRIPTS = \
+ $(wildcard $(EXTDIR)/*$(EXTVERSION).sql) \
+ $(wildcard $(EXTDIR)/*$(EXTVERSION)next.sql) \
+ $(NULL)
+uninstall-upgrade-paths:
+ rm -f $(INSTALLED_UPGRADE_SCRIPTS)
#only extension files
DATA = ${EXTENSION}.control sql/$(EXTENSION).sql $(wildcard sql/*--*.sql)
EXTRA_CLEAN += $(wildcard expected/*--*.out)
Modified: trunk/extensions/postgis_topology/Makefile.in
--- trunk/extensions/postgis_topology/Makefile.in 2017-10-22 21:30:16 UTC (rev 16054)
+++ trunk/extensions/postgis_topology/Makefile.in 2017-10-22 21:32:19 UTC (rev 16055)
@@ -101,6 +101,16 @@
done
+ $(NULL)
DATA = $(wildcard sql/*--*.sql)
EXTRA_CLEAN += sql/$(EXTENSION)--$(EXTVERSION).sql sql/$(EXTENSION)--unpackaged--$(EXTVERSION).sql
