[postgis-tickets] [PostGIS] #3914: ERROR: XX000: SQL/MM Spatial exception - geometry crosses edge 3051
PostGIS trac at osgeo.org
Wed Oct 25 04:27:58 PDT 2017
 Reporter:  laopsahl  |      Owner:  pramsey
     Type:  defect    |     Status:  new
 Priority:  medium    |  Milestone:
Component:  postgis   |    Version:  trunk
 Keywords:            |
 The problem I am working on is described in
 https://trac.osgeo.org/postgis/ticket/3838 , but basically what I do is
 that I use Postgis Topology to merge updates updates from images into old
 vector dataset.
 I have forked out Postgis to https://github.com/larsop/postgis today so I
 can make tests that be pulled down when testing updates.
 This is output from  PostGIS_Full_Version()
 POSTGIS="2.5.0dev r16058" [EXTENSION] PGSQL="96" GEOS="3.6.1-CAPI-1.10.1
 r0" SFCGAL="1.3.0" PROJ="Rel. 4.9.3, 15 August 2016" GDAL="GDAL 1.11.5,
 released 2016/07/01" LIBXML="2.9.0" LIBJSON="0.12" TOPOLOGY RASTER
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3914>
