[postgis-tickets] r16063 - Upgrade during create extension from unpackaged
Sandro Santilli
strk at kbt.io
Wed Oct 25 23:46:51 PDT 2017
Author: strk
Date: 2017-10-25 23:46:50 -0700 (Wed, 25 Oct 2017)
New Revision: 16063
Removed:
trunk/extensions/postgis/unpackaged_check.sql.in
trunk/extensions/postgis_topology/unpackaged_check.sql.in
trunk/.gitignore
trunk/NEWS
trunk/extensions/postgis/Makefile.in
trunk/extensions/postgis_topology/Makefile.in
This commit does it for "postgis" and "postgis_topology"
extensions.
Closes #3913
Modified: trunk/.gitignore
--- trunk/.gitignore 2017-10-26 01:08:26 UTC (rev 16062)
+++ trunk/.gitignore 2017-10-26 06:46:50 UTC (rev 16063)
@@ -48,7 +48,6 @@
extensions/address_standardizer/us-*.sql
extensions/postgis/postgis.control
-extensions/postgis/unpackaged_check.sql
extensions/postgis/sql/
extensions/postgis/sql_bits/*.sql
extensions/postgis_sfcgal/Makefile
@@ -65,7 +64,6 @@
extensions/postgis_tiger_geocoder/sql_bits/tiger_geocoder_minor.sql.in
extensions/postgis_topology/postgis_topology.control
-extensions/postgis_topology/unpackaged_check.sql
extensions/postgis_topology/sql/
extensions/postgis_topology/sql_bits/*.sql
GNUmakefile
Modified: trunk/NEWS
--- trunk/NEWS 2017-10-26 01:08:26 UTC (rev 16062)
+++ trunk/NEWS 2017-10-26 06:46:50 UTC (rev 16063)
@@ -5,6 +5,7 @@
- #3876, ST_Angle function (Rémi Cura)
- #3564, ST_LineInterpolatePoints (Dan Baston)
- #3896, PostGIS_Extensions_Upgrade()
+ - #3913, Upgrade when creating extension from unpackaged (Sandro Santilli)
* Breaking Changes *
- #3885, version number removed from address_standardize lib file
@@ -20,8 +21,6 @@
- TopoGeo_addLinestring robustness improvements (Sandro Santilli)
#1855, #1946, #3718, #3838
- #3234, Do not accept EMPTY points as topology nodes (Sandro Santilli)
- - #3892, Prevent version mixup when creating extension from unpackaged
- (Sandro Santilli)
- #1014, Hashable geometry, allowing direct use in CTE signatures (Paul Ramsey)
Modified: trunk/extensions/postgis/Makefile.in
--- trunk/extensions/postgis/Makefile.in 2017-10-26 01:08:26 UTC (rev 16062)
+++ trunk/extensions/postgis/Makefile.in 2017-10-26 06:46:50 UTC (rev 16063)
@@ -79,9 +79,9 @@
sql/$(EXTENSION)--$(EXTVERSION).sql: sql/$(EXTENSION).sql | sql
cp $< $@
-sql/$(EXTENSION)--unpackaged--$(EXTVERSION).sql: $(EXTENSION_UNPACKAGED_UPGRADE_SCRIPTS) ../../utils/create_unpackaged.pl unpackaged_check.sql Makefile | sql
+sql/$(EXTENSION)--unpackaged--$(EXTVERSION).sql: $(EXTENSION_UNPACKAGED_UPGRADE_SCRIPTS) sql/$(EXTENSION)--ANY--$(EXTVERSION).sql ../../utils/create_unpackaged.pl Makefile | sql
# Ensure version is correct
- cat unpackaged_check.sql > $@
+ cat sql/$(EXTENSION)--ANY--$(EXTVERSION).sql > $@
cat $(EXTENSION_UNPACKAGED_UPGRADE_SCRIPTS) \
| $(PERL) ../../utils/create_unpackaged.pl postgis \
Deleted: trunk/extensions/postgis/unpackaged_check.sql.in
--- trunk/extensions/postgis/unpackaged_check.sql.in 2017-10-26 01:08:26 UTC (rev 16062)
+++ trunk/extensions/postgis/unpackaged_check.sql.in 2017-10-26 06:46:50 UTC (rev 16063)
@@ -1,14 +0,0 @@
-DO $$
-DECLARE
- ver TEXT;
-BEGIN
- ver := split_part(postgis_scripts_installed(), ' ', 1);
- IF ver != '@EXTVERSION@' THEN
- RAISE EXCEPTION 'Installed PostGIS version is %', ver
- USING HINT = 'Try `CREATE EXTENSION postgis VERSION '''
- || ver || ''' from unpackaged`,'
- ' or source postgis_upgrade.sql`';
- END IF;
-END;
-$$ LANGUAGE 'plpgsql';
Modified: trunk/extensions/postgis_topology/Makefile.in
--- trunk/extensions/postgis_topology/Makefile.in 2017-10-26 01:08:26 UTC (rev 16062)
+++ trunk/extensions/postgis_topology/Makefile.in 2017-10-26 06:46:50 UTC (rev 16063)
@@ -60,17 +60,12 @@
sql_bits/topology_comments.sql: ../../doc/topology_comments.sql
cp $< $@
-sql/$(EXTENSION)--unpackaged--$(EXTVERSION).sql: ../../topology/topology.sql ../../utils/create_unpackaged.pl unpackaged_check.sql Makefile
+sql/$(EXTENSION)--unpackaged--$(EXTVERSION).sql: ../../topology/topology.sql ../../utils/create_unpackaged.pl sql/$(EXTENSION)--ANY--$(EXTVERSION).sql Makefile
mkdir -p sql
- # Ensure version is correct
+ # Ugprade before packaging
cat $< | $(PERL) ../../utils/create_unpackaged.pl postgis_topology >> $@
-unpackaged_check.sql: unpackaged_check.sql.in Makefile
- cat $< \
- | sed -e 's|@EXTVERSION@|$(EXTVERSION)|g' \
#upgrade script should have everything but table, schema, type creation/alter
#NOTE: we assume all object definitions end in ;
#first expression deletes all non-removable objects defined on same line
Deleted: trunk/extensions/postgis_topology/unpackaged_check.sql.in
--- trunk/extensions/postgis_topology/unpackaged_check.sql.in 2017-10-26 01:08:26 UTC (rev 16062)
+++ trunk/extensions/postgis_topology/unpackaged_check.sql.in 2017-10-26 06:46:50 UTC (rev 16063)
@@ -1,14 +0,0 @@
-DO $$
-DECLARE
- ver TEXT;
-BEGIN
- ver := split_part(postgis_topology_scripts_installed(), ' ', 1);
- RAISE EXCEPTION 'Installed PostGIS Topology version is %', ver
- USING HINT = 'Try `CREATE EXTENSION postgis_topology VERSION '''
- ' or source topology_upgrade.sql`';
- END IF;
-END;
