[postgis-tickets] [PostGIS] #3914: ERROR: XX000: SQL/MM Spatial exception - geometry crosses edge 3051
PostGIS trac at osgeo.org
Wed Oct 25 23:59:22 PDT 2017
  Reporter:  laopsahl  |      Owner:  pramsey
      Type:  defect    |     Status:  new
  Priority:  medium    |  Milestone:
 Component:  postgis   |    Version:  trunk
Resolution:            |   Keywords:
Comment (by laopsahl):
 I have simplified the test at https://github.com/larsop/postgis/blob/svn-
 trunk/topology/test/regress/snapto_tc1.sql
 I have also made a new test https://github.com/larsop/postgis/blob/svn-
 trunk/topology/test/regress/snapto_tc2.sql where I have broken the failing
 linestring into single line pieces and then I am able to add the data
 without any errors.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3914#comment:2>
