[postgis-tickets] [PostGIS] #3919: Broken upgrade: ERROR: function geometry_hash(geometry) does not exist
trac at osgeo.org
Thu Oct 26 00:27:37 PDT 2017
Reporter: strk | Owner: pramsey
Type: defect | Status: assigned
Priority: blocker | Milestone: PostGIS 2.5.0
Component: postgis | Version: trunk
Keywords: |
From our good Dronie bot:
https://drone.osgeo.org/postgis/postgis/632
Preparing db 'postgis_reg' using: CREATE EXTENSION postgis VERSION '2.1.2'
Upgrading PostGIS in 'postgis_reg' using: ALTER EXTENSION postgis UPDATE
TO '2.5.0dev'
Died at run_test.pl line 1423.
failed (Error encountered altering EXTENSION POSTGIS:
/tmp/pgis_reg/regress_log)
createlang: language "plpgsql" is already installed in database
"postgis_reg"
CREATE EXTENSION
CONTEXT: SQL statement "
CREATE OPERATOR CLASS hash_geometry_ops
DEFAULT FOR TYPE geometry USING hash AS
OPERATOR 1 = ,
FUNCTION 1 geometry_hash(geometry);
PL/pgSQL function inline_code_block line 4 at EXECUTE statement
r16058 was the first failing commit.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3919>
