[postgis-tickets] [PostGIS] #3912: glibtoolize doesn't install install-sh
PostGIS trac at osgeo.org
Thu Oct 26 00:42:09 PDT 2017
  Reporter:  pramsey  |      Owner:  strk
      Type:  defect   |     Status:  reopened
  Priority:  blocker  |  Milestone:  PostGIS 2.2.7
 Component:  postgis  |    Version:  2.4.x
Resolution:           |   Keywords:
Comment (by strk):
 Make sure there's no "install-sh" in your path when running ./autogen.sh,
 try moving source tree around. Also see if adding {{{ AC_PROG_INSTALL }}}
 to {{{ configure.ac }}} helps.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3912#comment:11>
