[postgis-tickets] [PostGIS] #3913: Include minor upgrade in extension-from-unpackaged script
trac at osgeo.org
Thu Oct 26 02:25:29 PDT 2017
Reporter: strk | Owner: robe
Type: defect | Status: reopened
Priority: medium | Milestone: PostGIS 2.5.0
Component: postgis | Version: 2.4.x
Resolution: | Keywords:
Changes (by strk):
* status: closed => reopened
* resolution: fixed =>
Comment:
I think this commit might have introduced a conceptual error.
When including minor upgrade it may happen that the minor upgrade runs a
{{{ CREATE }}} statement, so that the created new object is installed in
the target extension automatically.
Later on, when {{{ ALTER EXTENSION .. ADD }}} is called if the object is
already in the extension you get an error like: {{{ ERROR: view
raster_columns is already a member of extension "postgis" }}}
Regina: can you produce such occurrence ? I'm not sure our bots are
triggering it (but could be wrong) -- I'm getting it manually from my
"split-raster-from-core" branch...
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3913#comment:4>
